Lifting Engine, What size bolts
Old May 4, 2015 | 06:07 AM
bashcraft's Avatar
bashcraft
You guys that are afraid of using a lift plate need to take a couple engineering classes.
Old May 4, 2015 | 11:21 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
so what is the pull out strength of 1/4" tapped used holes into 50 year old aluminum intake ? ?
this is the unknown factor... the strength of the bolt is not, what concerrns me.
opps bubba cross threaded those holes 30years ago, no worries they only held the carb. on.
me personally, I would not chance a lift plate using a aluminum intake lifting 1000lbs BB,
over a plastic/fiberglass fender to remove a motor.
much saver with chains and 3/8's bolts into steel block and heads.
everyone makes their own judgment call on safety, I prefer the safe side vs the risk side.
to the original poster your minor lift is just fine, with the lift plate.
Old May 4, 2015 | 03:00 PM
Cavu2u's Avatar
Cavu2u
opps bubba cross threaded those holes 30years ago, no worries they held the carb. on.
Steve
Old May 4, 2015 | 03:18 PM
keithinspace's Avatar
keithinspace
FYI, my engine builder had a HOLE conveniently placed through his hand (as in through...front-to-back) while lifting an engine with a carb plate. It "let go" when he was guiding the engine over the fender. Knarly scar. And please don't say "he didn't know what he was doing"...he is one of the very few people I know who is more ****-retentive than I am when it comes to doing things right.
Needless to say, that was the last time he used a carb plate.
Even an iron intake is cast. Internal graining is inherent/fundamental to a cast iron part and they simply are not constructed or intended to act as stress members or to have a great deal of torsion/tension/shear applied to them.
This is "one of those things" that is done regularly by a lot of people. And rarely does anything happen. But there is no reason on God's green earth to take the chance.
Use bolts in the heads. There just isn't any guesswork involved.
Old May 5, 2015 | 09:53 PM
BLUE1972's Avatar
BLUE1972
Soak the bolts with FREEZ-OFF and it will loosen easier...
Old May 5, 2015 | 10:22 PM
John Holmes's Avatar
John Holmes
The dude is either inept or incompetent, good threads and good bolts will support a big block for longer than you or I will be around.
Old May 6, 2015 | 01:21 AM
7T1vette's Avatar
7T1vette
The "proof load" of a Grade 2 5/16"-18 bolt is 2900 lbs. That's for one bolt. A grade 5 bolt has a "proof load" of 4450 lbs. Now, that doesn't speak to the strength of the aluminum threads, but I think you folks can see that four (4) 5/16"-18 bolts, secured tightly over a steel plate into even aluminum threads (of any age and 'reasonable' condition) would safely lift a 1000 pound engine (fully dressed big block).
Would I agree that lifting with a good chain and two steel lift-loops bolted via the intake manifold would be somewhat safer? Well, probably. But, that depends on the chain, doesn't it?
If you just spin 4 bolts through the carb plate and don't tighten them securely, I wouldn't lift it on a bet....
Old May 6, 2015 | 10:03 AM
keithinspace
Originally Posted by John Holmes
The dude is either inept or incompetent...
Respectfully, he is neither.
The aluminum manifold failed, not the bolts. The bolts are not at issue. You can bolt as many Grade 8 bolts as you want into something...if the engine is on the ground and the cast intake is broken in half, it doesn't make a damn difference what type of bolts you used.
A manifold is made to connect a carb to the heads. It is not made, designed, constructed, cast, modeled, optimized, built, nor INTENDED to hold a 1,000 lb engine in the air.
999 out of 1,000 people may not have a problem. That's fine. My engine builder, having dealt with thousands of engines over his life, finally had it catch up with him.
At worst, that makes him unlucky. But not inept or incompetent, thank you.
Old May 6, 2015 | 10:44 AM
Cavu2u's Avatar
Cavu2u
Steve
Old May 6, 2015 | 05:24 PM
roscobbc's Avatar
roscobbc
I wonder if a discussion about the relative merits of different quality/tensile strength con rod bolts would have generated as much discussion as mere engine lift bolts
Old May 6, 2015 | 06:45 PM
Cavu2u's Avatar
Cavu2u
Steve
Old May 6, 2015 | 08:02 PM
BLUE1972's Avatar
BLUE1972
It's no so much the grade of the bolts but the fit.(thread %)
That is why the tap charts show different drill for different % fit.
I almost lost a finger helping a friend lift a big block with a 4 speed when the rear bolt came out of the engine head, he is cheep and used box store bolts. the threads came off the ice-cream soft bolt.
Most manufacturers know people use the manifold to lift and include this in the design. Otherwise the manifolds would be 1/2 the thickness. There would also be warnings in the box, on the box, on the manifold and stickers everywhere not to use it for lifting.
I would guess that if you "port" the crap out of a manifold and leave thin spots it will crack.
Yes I was a design engineer...
Old May 7, 2015 | 03:54 PM
  #33
roscobbc's Avatar
roscobbc
My son is in to BBF's - currently has a '62 TBird with warmed over 390 and an early Dord ex-Shelby Cobra style dual quad Ford inlet manifold. Now that you most certainly wouldn't use that inlet for 'lifting' - being also a dual plane configuration (just think about it - dual quad AND dual plane) its really quite a delicate casting
Old May 7, 2015 | 04:04 PM
  #34
bashcraft's Avatar
bashcraft
Not really. I had a 69 Mach I with a 390 and FoMoCo medium rise dual quad manifold. Probably the same kind your son has. I picked it up several times with a lift plate that was redrilled to use 2 studs from each carburetor.
