Lifting Engine, What size bolts
Old Apr 30, 2015 | 10:19 PM
wheatpj's Avatar
wheatpj
Default Lifting Engine, What size bolts
I’m going to use an engine lift plate to lift my big block. I’m not pulling the engine, just lifting it enough the pull the harmonic balance and replace motor mounts. What size bolts should I use to attach the plate to the intake manifold?
Old Apr 30, 2015 | 10:26 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
This is the plate that attaches to carb pad? Only choice is 5/16 coarse thread....just make sure they go as deep into intake as possible.
Or hook a chain across any bolt holes on the ends of the heads.
Or a block of wood under the oil pan and a jack....
JIM
Old Apr 30, 2015 | 10:33 PM
wheatpj's Avatar
wheatpj
JIM
Yes, attaches to the carb pad. I guess question really is how long? I don't want to be too short or too long.
Old Apr 30, 2015 | 11:31 PM
427Hotrod's Avatar
427Hotrod
Just go as deep as the intake allows. Depends on what intake you have.
JIM
Old May 1, 2015 | 06:32 AM
Cavu2u's Avatar
Cavu2u
Wheatpj,
If I understand this right;
You don't want to do more than required.
Instead of removing the carburetor, do what Jim suggested and lift the engine with chains attached to bolts screwed into the front-facing cylinder head.
Or, lift the engine by way of a couple of intake manifold bolts.
Steve
Old May 1, 2015 | 10:06 AM
wheatpj's Avatar
wheatpj
Originally Posted by Cavu2u
Wheatpj,
Steve
That's right, don't want too much or to little.
I am already taking the carb off to work on it. I already have the lifting plate and will leave it on to block the intake manifold until I put the carb back on.
I am probably good if I can get the bolts threaded at least a 1/2 inch into the manifold.
Old May 1, 2015 | 11:58 AM
bashcraft's Avatar
bashcraft
Preferred thread engagement is around 1-1/2 times the bolt diameter. So 5/16 x 1-1/2 = ~1/2"
Old May 1, 2015 | 12:04 PM
Cavu2u's Avatar
Cavu2u
Old May 1, 2015 | 04:21 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
scares me to lift a BB with a carb. plate, .... they are heavy !
and those carb. bolts are small ! good luck !
Old May 1, 2015 | 05:55 PM
Cavu2u's Avatar
Cavu2u
I thought about that too.
Steve
Old May 1, 2015 | 05:56 PM
roscobbc's Avatar
roscobbc
Moved mine from engine bay a few weeks ago with a lift plate - and into van last weekend to send to engine builder - no problems whatsoever. Trick probably is to make all movements gently - no sudden jolts to put a strain on inlet manifold
Old May 1, 2015 | 08:35 PM
BLUE1972's Avatar
BLUE1972
Just used the lift plate, put in the engine with the tranny (5 spd) no issues. Engine builder used the plate to load the motor with the cart into my truck via forklift.
He said he uses the plate due to not wanting to scratch the paint. He said he lifted all motors including 600 cu race motors.
The engine builder used grade 8 bolts that were deep into the carb mounts.
Prefer the chains to the 4 corners of the block / heads with a tilt / balancer bar. Just easier to tilt.
I would guess the BB engine is 600 -700 lbs. + 125 for the trans/clutch/bell housing. Each bolt can hold 2+ times that.....
Old May 1, 2015 | 10:03 PM
Cavu2u's Avatar
Cavu2u
I use this, just like you Blue1972
Pretty unbelievable, 4 little bolts, holding all that weight.
Wheatpj: Go for it!
Learn something new everyday.
Steve
Old May 1, 2015 | 10:57 PM
wheatpj's Avatar
wheatpj
Wheatpj: Go for it!
Steve
I'm just lifting it a few inches to change out the harmonic balancer and the motor mounts. I don't think I would try to lift it over the fenders with the plate. The 4 chains and the leveler looks to be a better option for that.
Thanks everyone for the advice.
Pat
Old May 2, 2015 | 01:10 AM
John Holmes's Avatar
John Holmes
He doesn't need "luck", the 5/16 bolts are plenty strong enough.
Myself and countless others have done it countless times without incident.
Old May 2, 2015 | 04:52 AM
7T1vette's Avatar
7T1vette
Using the carb plate and 5/16" bolts is not a problem. BUT, the bolts need to completely seat on the plate (lock it down to the carb gasket surface) and be Grade 5 bolts. Using bolts that are too long will result in side-loading of the bolts when the engine is lifted. I agree that the bolts need to be as long as possible but without bottoming in the threaded hole. Use of spacers or flat washers to take up extra bolt length is fine. Torque the bolts to nominal bolt torque load for that size and grade of bolt (19 ft-lbs if dry; about 15 ft-lbs if oily).
Old May 2, 2015 | 06:17 AM
roscobbc's Avatar
roscobbc
If the lift plate to carb mounting is 100% secure as above - then putting the lifted load across the multiple inlet manifold to head bolts (despite the low torque settigs) is as secure as 4 no. bolts in cylinder heads
To Lifting Engine, What size bolts
Old May 2, 2015 | 07:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
OR, as previously mentioned, simply stick a short piece of 2x10 wood under the oil pan, and CAREFULLY raise the engine with a jack.
WAY too much "overthinking" going on here......
Old May 2, 2015 | 10:39 AM
jnb5101's Avatar
jnb5101
When you mention lifting the engine a few inches, remember there's lots of other stuff attached besides the engine mounts. Clutch/ transmission linkage, trans mount bolted to the frame, exhaust pipes will lift with the engine but the crossmember won't, radiator hoses, fuel lines, electrical cables, valve covers may strike P/B booster. Probably some others that slip my mind right now. In a tight engine compartment as a vette has, there's not a whole lot of free space.
Old May 3, 2015 | 10:23 AM
wheatpj's Avatar
wheatpj
thanks for the heads-up. Most everything is off the front of the engine except for the blasted harmonic balancer which is the reason I now have to lift the engine. Exhaust pipes detached from the headers and trans mounts are loosen. I got the clutch linkage. No power brakes and I think the hoses and wire cables should give me enough slack to raise the engine enough to get the balancer off a replace the mount mounts.
The option of jacking the engine from the underneath using the oil pan was considered, but that make me a little queasy. We used that method when we had to raised the engine in my son Mustang GT for a header install, but the oil pan on that little engine looks way stronger. I'm afraid weight of that big 454 and trans would bent my oil pan like a beer can. I probably am over thinking it.
Yesterday, I spent must to of the day battling with a motor mount bolt (the long one). I had to take the power steering pump off to get a good shot at it with my impact wrench. Seems you always come up a few millimeters short on clearance on this car. This is turning into one of those what did I get myself into projects. If I can find the time, today I will tackle the other motor mount bolt. I will probably have to pull the starter to get it out.
