waxing
Old May 3, 2015 | 01:30 PM
sheepdawggerry's Avatar
sheepdawggerry
Default waxing
I have a 74 Corvette with original white paint. Should I wax the vehicle every year or not. I gave it a good waxing last year , it's my Second year that I owned it, and had it covered over the winter and it's surface is very slippery still. Should I just use a detailer spray? And wax it every other year or every third year?thank you for any response
Old May 3, 2015 | 01:44 PM
ddawson's Avatar
ddawson
I do it every year and clay if needed.
Keeps a nice shine and you know it's protected.
Old May 3, 2015 | 02:26 PM
mortgageguy's Avatar
mortgageguy
Original paint! Wow. White paint needs and responds well to a good cleaner wax. You would be amazed at the impact it would have on your car. You should hit it with Meguairs white wax. It's an all in one product that cleans and waxes. As to how often to wax, I think it should be waxed annually at the very least. I clay mine on the horizontal surfaces each year. It always surprises me what gets embedded in your paint even when it is a garaged car.
Old May 4, 2015 | 10:35 AM
Peterbuilt's Avatar
Peterbuilt
Default I'm brainwashed!
White Wax for white cars! Yes I fell for that pitch too since I have a white 74.
I'm not sure if there is anything special in it for white paint but it does shine up nice.
Seems to work just fine on any color.
Old May 4, 2015 | 03:45 PM
mortgageguy
Not a gimmick, white wax has more abrasives for cleaningl light colored cars, black wax has more polishing oils for dark colors. Yes white wax can be used on any color car for paint cleaning. Any cleaner wax can be used.
I didn't get the feeling from the OP that he wanted to spend a lot of time detailing his car. I, on the other hand, enjoy it. I clay, Polish, and wax all my cars multiple times each year. OP can get the biggest bang for his time by doing an AOI cleaner wax once per year.
Old May 4, 2015 | 05:03 PM
Scottd's Avatar
Scottd
How often you wax depends on how often you wash. I wash my car about once a week in the summer, and I wax when water no longer beads up on the hood. (usually every 4 washes)
Mcguires gold class all the way. Best wax on the planet. (I worked for a auto store in college and tried EVERY product out there)
Old May 4, 2015 | 05:29 PM
lurch59's Avatar
lurch59
I've just repainted my 69, and have been told that there is no need to wax a car with a clear coat finish. What do y'all think?
Old May 4, 2015 | 07:36 PM
silvvette's Avatar
silvvette
I heard the same (eg not using wax on clear coat) I only use polish. Once every 3 month (you can go longer than 3 months) works great - the finish is like glass and smooth as silk.
Old May 4, 2015 | 08:15 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
I also just use polish. I have good results with Adam's "Brilliant Glaze" on both clear coat and non clear coat finishes.
Old May 4, 2015 | 09:00 PM
mortgageguy
To my knowledge, no automotive producer in the world, nor paint supplier, has produced a paint that can withstand the sun, industrial fallout/pollution. Much less water spots and bird droppings. You have invested too much money in your 69 to ignore the upkeep on a new paint job.
Old May 4, 2015 | 09:03 PM
mikem350's Avatar
mikem350
Back to the OP with original paint. I am assuming that it is not clearcoated. The last thing you want to do is remove any paint. I would say a light waxing once a year is perfect. If well taken care of garaged etc, I would just take a California Duster instead of frequent washings!
This is the way I cared for my all original white 73 Firebird
Old May 5, 2015 | 10:56 AM
lurch59's Avatar
lurch59
Well, you've given the only reason that would trump my firm commitment to laziness. I spent a lot of money on the paint job, and it has 4 clear coats over the Daytona yellow paint. I'd like to never do that again.
I do know that there are waxes with polishes in them, to save a step so to speak. Polishing is abrasive, and as you move through finer and finer polishes the surface appears smoother. Therefore, one should only polish to restore the surface, and wax should be applied to protect from the elements. I respectfully disagree with polishing every time, you are removing layers.
Old May 5, 2015 | 11:02 AM
lurch59's Avatar
lurch59
I don't know how long waxes last, but have read that cheap wax lasts 3months and expensive wax lasts 90 days. It's a pretty thin coat, and yes I used to wax all my cars every three months.
I don't like the California duster (I have one) because I want to float the dirt with water before rubbing it, and rinsing does get some of the dust off so less scratching. I wish it was the best because it is easy, but IMO there is no substitute for the old fashioned methods. I think some of this theory comes from the environmentalists who don't want us "wasting" water.
Old May 5, 2015 | 11:28 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Zaino Bros. I was dubious as to whether it would really give a lasting shine. It does.
Old May 5, 2015 | 12:13 PM
lurch59's Avatar
lurch59
Is this because it polishes (wears) the paint, or are you seeing the wax coating the paint longer? I don't know the answer, but it seems like someone somewhere could have tested for the presence of a coating of wax monthly after the initial waxing, and given us a guideline.
The old standard was whether water beaded up on the paint when washed, and by that standard my experience is that wax doesn't last a year.
Old May 5, 2015 | 02:22 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
If it wears the paint (which I doubt), I never noticed. I used this product, a synthetic polymer I believe is a more accurate description, on two black 370Z's I previously owned. I applied two or three applications over a few weekends in the spring and that was it. A quick spray detailer once in a while throughout the summer/fall. The cars always beaded the water like it was just waxed when the suds were hosed off. I just like the fact that with a little effort up front doing the applications it paid off in spades in the long run.
Old May 5, 2015 | 03:30 PM
mortgageguy
You are correct, Polish does have a degree of abrasives. It is an excellent product for minor corrections such as light swirl marks, and no matter how careful you are, you will have some swirl. Polish is also what gives your paint its depth of shine.
An excellent and easy way to make a wax job last a year, is use one of the quick spray waxes once per month to boost the yearly wax job. I just spray it on as I'm drying my car after a wash. Then dry it off with a mf towel.
Old May 7, 2015 | 01:31 AM
7T1vette's Avatar
7T1vette
Depends on where you live. If you live in moderate climate, waxing is fine. Maybe a lot of work (depending on brand of wax), but it will protect fine. If you wash the car a lot using a soap, you will lose some wax every time you wash, so you'll need to wax more often.
If you live in hot, sunny climate, you might want to consider a polymer polish, rather than a wax. Wax tends to dry out and start 'checking' under hot, sunny conditions. I found that out when I lived just west of Phoenix, AZ. I converted to polymer polish (Zaino) and have never gone back to wax. Polishing is much easier and lasts longer.
To waxing
