Automatic Dipstick Reading
Old May 3, 2015 | 09:36 PM
doning's Avatar
doning
Default Automatic Dipstick Reading
I hope this is not going to sound stupid, but on my 80 Corvette I am having trouble seeing the oil level on my dipstick. When the engine is hot at idle when I pull it out I cannot see the oil mark. I know there's oil there but it does not leave a noticeable line. My front pump leaks a little so I want to make my level is always up. Any tricks to be able to read the level? I added some oil today and now not sure if I gave it enough or too much. Thanks. Don
Old May 3, 2015 | 10:05 PM
Frank_Nesta's Avatar
Frank_Nesta
You could wipe the dip stick clean. Reinsert it and bring it out and wipe down the dip stick slowly with a clean paper towel until you first see oil and see where the level is.
Old May 3, 2015 | 11:22 PM
OMF's Avatar
OMF
If you wipe the dipstick really clean and dry, then reinsert and pull back out. Now angle the dipstick down and away from you, and face the sun.....the oil is will show glossy wet whereas the stick will be a flater shade. The real trick is to wipe the dipstick dry the first time around.
I sure hope I haven't been trolled.....
Old May 3, 2015 | 11:34 PM
7T1vette's Avatar
7T1vette
Your trans oil could be low....
Old May 4, 2015 | 12:18 AM
mikem350's Avatar
mikem350
Check it with engine OFF, oil has to settle back down into the pan. Wait couple mins.
Old May 4, 2015 | 06:11 AM
bashcraft's Avatar
bashcraft
Wrong. The engine must be running to check the oil level in an automatic transmission. It also needs to be up to operating temperature.
Old May 4, 2015 | 07:48 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
True, but if the OP checks the fluid with the engine off, he should see what it looks like on the dipstick. If he doesn't see it with the engine off, I'd suspect that the dipstick is either wrong or broken.
Old May 4, 2015 | 12:41 PM
doning's Avatar
doning
With the engine off and cold I can see red all the up to the full mark and a little past.
Old May 4, 2015 | 02:26 PM
7T1vette's Avatar
7T1vette
It should be quite a bit high on the stick, when engine is OFF. You must be low on fluid. Put one quart of fluid in the fill tube, then warm engine and check again with transmission in "Drive" range. Fully warmed oil should be at the FULL mark.
Old May 5, 2015 | 06:16 AM
doning's Avatar
doning
Thanks Guy's for your help. A friend of mine told me to drill small holes where the checkered area was. "That might help" he says. The oil will fill the holes and give you your level. This is my first time owning an automatic. I always drove standard shift. Why do you check transmission oil with engine running? Why don't they have you check it like you do with engine oil...engine off?
Old May 5, 2015 | 07:04 AM
flyeri's Avatar
flyeri
It is checked hot and running because when running, the torque converter, valve bodies, and all components have sufficient fluid to work properly and you are checking the supply in the pan. When not running and cold the level may or may not be consistent from one shut down to another due to drain back from those areas of the tranny.
Old May 5, 2015 | 12:59 PM
1Fordman's Avatar
1Fordman
In the past on some dipsticks that are shiny and hard to read, paint the first 3 inches with VHT high heat flat black exhaust paint. The fluid really stands out on the flat black.
To Automatic Dipstick Reading
