VIR Construction Question
Old May 8, 2015 | 12:20 PM
Cavu2u's Avatar
Cavu2u
Default VIR Construction Question
Am I correct in assuming this VIR Air Valve Housing is a press-in fit, or by some chance a screw-in type?
Thanks.
Steve
Old May 9, 2015 | 02:07 PM
'75's Avatar
'75
Not removable, made together. You can change the schrader valve though.
Old May 9, 2015 | 09:14 PM
Cavu2u's Avatar
Cavu2u
Well.......
That's the problem.
I went to remove the old Schrader Valve, as a new one came with the kit. The old one in there didn't want to come out, like a conventional one that just screws out. It unscrewed but remained held in there. I got a needle nose on it and pulled: some of it came out, some of it remained in there. Now I got a mess on my hands and not sure how to proceed. To trash a whole VIR Top just because of a busted Schrader Valve doesn't sit well with me.
Steve
Old May 10, 2015 | 10:30 AM
Cavu2u's Avatar
Cavu2u
After thought, I could drill and re-tap for a new Schrader valve, but don't these valves require a seat?
Steve
Old May 10, 2015 | 10:42 AM
'75's Avatar
'75
Check the local parts store for a combination tool that has an easy-out, tap and die for tire valve stems. The easy-out should get the old piece of the schrader valve out.
Tool
Old May 10, 2015 | 12:25 PM
1Fordman's Avatar
1Fordman
Tool
This tool works great, have had one for years and it's saved me a few times.
Both tire stems and a/c work.
Old May 10, 2015 | 02:40 PM
Cavu2u's Avatar
Cavu2u
Thanks for the tip guys. I forgot all about that tool. Everyone out there at the shop has one in their toolbox!
I first screwed the tap side of the tool down in there. Screwed it in pretty hard too, until I could not turn it anymore by hand (fingers). It compressed what valve remanents were in there.
Then I took a 5/32" drill bit and went at it. I then pulled this out.
The old valve part just stuck to the drill bit.
Hole now clear;
..and accepts a new air valve.
Blind luck.
Steve
Old May 10, 2015 | 03:59 PM
'75's Avatar
'75
No such thing as good luck, it's just good wrenchin'.
Old May 10, 2015 | 06:16 PM
Cavu2u's Avatar
Cavu2u
Default Thanks for the help folks.
Next challenge: Engineer this tool to remove the Expansion Valve Capsule so as to clean and replace the O-rings inside. It's really gummed up and somewhat "glued" in place.
Steve
To VIR Construction Question
