timing light hook up
Old May 8, 2015 | 11:18 PM
koolbz's Avatar
koolbz
Cruising
Default timing light hook up
Hey guys, new to the corvette world and I have a question about hooking up a timing light. With the battery behind the seat, where can I hook up the power leads for the light. the leads on my craftsman timing light are not long enough to reach the battery. Any ideas would be great. was wondering if I can hook the to the alternator and engine block to power it. thanks for the help, you guys rock
Old May 8, 2015 | 11:23 PM
Haggisbash's Avatar
Haggisbash
That's how I do it.
Old May 9, 2015 | 01:41 AM
dugsgms74's Avatar
dugsgms74
I grab power off the horn relay, same idea.
Old May 9, 2015 | 02:54 AM
Joebrick's Avatar
Joebrick
I use the alternator leads. Just don't do like I did a few years ago and accidentally touch one to the other. "Spark".....fried the alternator.
Old May 9, 2015 | 03:17 AM
Iceaxe's Avatar
Iceaxe
Any 12 volt source will work, the battery doesn't even need to be in your car. But as mentioned above, I pull off the alternator.
Old May 9, 2015 | 08:19 AM
Street Rat's Avatar
Street Rat
I use the positive post on the alternator and a ground on the engine or frame.
Old May 9, 2015 | 09:12 PM
koolbz's Avatar
koolbz
Cruising
Thanks guys, used the alternator post. Work like a charm.
To timing light hook up
