'73 454 won't start
I've poured over this forum looking for pertinent information. I thought I found the right info, but it just hasn't panned out. So I'm sorry for asking you what I'm sure you've answered 100's of times already.
1973 454 auto tilt tele
Turn key, starter engages, but no start. release key out of starting sequence...nothing. Turn key back towards off and as I am turning out of the run position, the engine coughs and acts like it just tried to start. So, engage starter, it turns over, but no ignite, release starter nothing, move key towards off and motor coughs.
I did a search here, coupled with another tech I know and decided to install a new ignition switch. The key cylinder was badly worn as well, so I installed a new one also, all from dealer.
STILL COULDN'T GET IT TO WORK and I was second guessing my install. So I sent the column to the other Chevy Tech I know and he put everything together and said I'd be good to go.
Got column home, plugged it in, SAME THING. Almost no change. Called the tech and he's now out of town camping for a few weeks and is out of contact.
Could I be addressing this issue on the wrong side of the firewall?
I have a mallory electronic distributor with a mallory coil and ballast resistor.
Any suggestions?
My thought would be....because the engine will spin over but not ignite....I would be looking at the power getting to the coil when the key is in the START and RUN positions.
WHY and I writing this....because often times....the wiring to the coil/distributor is NOT getting 12 volts when the key ids in the STARTING position....and is still not getting 12 volts when it is in the RUN position....BUT....when you turn it to accessory....it gets 12 volts and is igniting the fuel that is still in the cylinders.
DUB
Basically the key ignition switch on the column connects to a rod which activates the ignition/start switch mounted a foot or so down the column. The wires running in the column- AKA harmonica connector- don't have anything to do w/ the keyed ignition switch except activate the warning key in ignition buzzer. Those wires are for the turn/hazards/horn.
So no matter how worn the actual key tumbler part is-as long as the rod is moving the ignition switch- that's not your problem....
Here's the actual switch-that electrically controls your ignition & starter
DSCN5195 by Richard Hayes, on FlickrThe wires that plug into the switch-
DSCN5194 by Richard Hayes, on FlickrHere's the wires mapped out-what they do-
starter wires by Richard Hayes, on FlickrThe mechanical rod that controls the seitch-
DSCN5205 by Richard Hayes, on FlickrWhere the rod connects- you can use a small screwdriver and control the ignition/start w/o the key once disconnected from the steering column=
DSCN5206 by Richard Hayes, on Flickr
I've even removed the ignition switch with the plugs still in place and instead of moving the key, I moved the ignition switch itself and same thing, Can't get it to fire until I move from run to off.
Any suggestions?
My HEI voltage reading was at 11.2V and it would not start. After charging my battery for 8 hours with trickle charger and having 12.2V at Mallory HEI started the engine immediately.
I thinking not enough juice to get the HEI supply sparks.
Hope it works for u tho.
A friends 64 Nova did this.....if you could get the engine spinning fast enough it would fire as you released the key.....
The R side gives it power during cranking.
Pink wire in the diagram...
Jebby
I don't know if this will help or not but here is the sequence built into the ignition switch.
From full clockwise to full counterclockwise:
START with spring return to RUN
RUN with detent to get to next position OFF
OFF with another detent to get to OFF-LOCK
OFF-LOCK with another detent to the ACCESSORY position.
So there are five positions built into the switch itself. You should be able to distinctly feel all five positions by moving the slider on the underside of the ignition switch.
To synchronize the ignition switch to the steering column requires the following procedure.
With the steering column out of the car, and the ignition switch removed from the column. Now move the lower lever DOWN to its lowest position. Rotate your ignition lock cylinder and key CCW from full CW until it stops. Your ignition lock cylinder (and steering column) are now in the OFF position.
Now take your ignition switch and move the slider into the START position, (you will feel the spring pushing against you.) The spring should place you in the RUN position. Now move the slider to the next detent position. You are now in the OFF position. You now have the ignition switch and your steering column both in the OFF position.
Carefully install the ignition switch on the steering column rod (being careful to not disturb the slider position. Lightly push down on the switch to take slack out of the system. Tighten the two nuts that hold the switch to the column jacket.
Now when you move the lower steering column lever to the full UP position, you should be able to continue rotating your ignition key and lock cylinder CCW to the OFF-LOCK and ACCESSORY positions.
Jim
After running out of combinations of changes all centered around the ignition switch on the steering column, I screwed the switch down in place and said to myself, "IT'S NOT THE IGNITION SWITCH!" and began hunting for issues on the other side of the firewall.
I found a loose wire on the wire loom. I tested it for voltage and it was hot all the time as long as the battery was hooked up. so I secured it back in place in the loom AND....NOTHING. no change...SO...
I started checking the voltages at various places. Voltage to Coil from Ballast resistor was 4 volts. I thought, maybe this was the problem. Bought new ballast resistor, installed it AND...Nothing! I checked the voltage and still 4 volts going from ballast to coil, full 12 to ballast from ignition when in the RUN position....SO, I said "The hell with it." I'll remove the ballast all together because I can't exactly remember why I have the ballast in there in the first place. I have a Mallory HEI pointless ignition and a High Energy Coil. I figured, at this point worst case I burn up the innards of the distributor.
So took un ballasted voltage wire directly to coil....BANG, fired right up!
I'm like WHAT!!!!????
Now that ballast has been in there for 25 or so years. Maybe the new one was junk, I don't really even know what they are there for...(I think to keep voltage even to the electronic ignition) But, without it, the car fires right up!!!
I'VE BEEN HUNTING THE PROBLEM FOR WAY TO LONG.
Mike
