Another engine build
Old May 28, 2015 | 09:18 PM
labhound's Avatar
labhound
Default Another engine build
I'm putting this out here for any advice/comments. The start is a .30 over 454, with about 10.5:1 comp, balanced rotating assembly, I'm gonna use my 781 heads that has had a sorta recent valve job so they seal great now, Edlebrock performer 2 intake, Holley 800 dp, OBX side pipes.
What the plan is, maybe a three angle job and clean up the ports/bowls on the heads.
A Comp Cam kit, http://www.summitracing.com/parts/cca-k11-420-8, that includes almost everything.
Keep the Performer 2 intake and use the Holley 800...
As of now, the stock gears will be used, 3.08 along with the close ratio stock 4 speed.
So, any thoughts of how this set up may work? I have this cam selected for it's rpm range with the stock gears.
Old May 28, 2015 | 09:48 PM
toobroketoretire's Avatar
toobroketoretire
That camshaft would be perfect for your tall 3.08 gears.
Old May 28, 2015 | 11:18 PM
bluedawg's Avatar
bluedawg
Looks like a good match, if your going to work on the bowls and runners maybe buy a cc kit measure the size of the first after you clean it up to keep all the other runners close to the same size. The big block I've got in the garage has 781s on it and the research I did on them shows they respond well to port work, mark Jones uses them to make phenomenal power, but he's a master heads and engine building, plus who knows how many hours he puts into them. Good luck.
Old May 29, 2015 | 04:41 PM
labhound's Avatar
labhound
Sounds good, could the 800 carb be too much for it maybe?
Old May 29, 2015 | 05:58 PM
bluedawg's Avatar
bluedawg
I don't think so, on my 400'' with afr heads and roller cam I run a prosystems 780 double pumper that according to prosystems flows 820 cfm. I ran my 650 cfm vaccum secondaries on it to see if it would gain bottom end and the the 780 dp ran just as well on the bottom end and was superior on the top end.
Old May 30, 2015 | 05:22 PM
toobroketoretire
A 750 cfm carburetor is all you need on a 454" like yours. I'm running a 236/236 degree .560" lift cam in mine and the secondaries will open about 95% under a full throttle at 5500 rpm so its a perfect match for my setup. More cam and higher revs would dictate a larger carburetor......................
Old May 30, 2015 | 06:09 PM
labhound's Avatar
labhound
Thanks, maybe I wasn't thinking much of the rpm that I normally drive.
So how's your set up run...?
Old May 31, 2015 | 07:41 AM
toobroketoretire
It runs fantastic. With it's 10 to 1 compression ratio it'll run great on 91 octane. I'm running a beefed TH700R4 with 3.70's (2.62 final drive ratio) and it cruises at 60 mph at only 2040 rpm.
Old May 31, 2015 | 07:58 AM
labhound's Avatar
labhound
I had my eye on a 3.70 posi unit at the Springfield swap meet, I should've made a deal on it....
Old Aug 8, 2015 | 08:04 PM
labhound's Avatar
labhound
Its running now!!! I still need another carbon and a final tune.
Old Aug 9, 2015 | 12:20 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
MONSTER!
Old Aug 9, 2015 | 11:55 PM
bluedawg's Avatar
bluedawg
Sweet! Congrats!
To Another engine build
