"Hair trigger" horn
Old Jun 23, 2015 | 10:34 PM
73C34me's Avatar
73C34me
Default "Hair trigger" horn
Rebuilt my steering column on my 73. Fixed my horn; now it works too good! I have to pull some tension on the horn button on the steering wheel to keep it from triggering the relay. How do I correct this? Thnx in advamce
Old Jun 24, 2015 | 01:35 AM
Iceaxe's Avatar
Iceaxe
Add more horn contact shims. I ended up using three after rebuilding my steering column. A set of 3 is available from most the vendors for under $10.
Old Jun 24, 2015 | 10:59 AM
73C34me's Avatar
73C34me
[thnx. I was suspecting that might be the fix.
QUOTE=Iceaxe;1589905241]Add more horn contact shims. I ended up using three after rebuilding my steering column. A set of 3 is available from most the vendors for under $10.[/QUOTE]
Old Jun 24, 2015 | 06:25 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
This might help:
https://www.corvetteforum.com/forums...-easy-fix.html
Old Jun 24, 2015 | 06:37 PM
73C34me's Avatar
73C34me
Thanks for the link!
To "Hair trigger" horn
