Mono Spring Question Suggestion
Old Jun 25, 2015 | 02:10 PM
Basque32's Avatar
Basque32
Default Mono Spring Question Suggestion
Hi all,
So I'm working on getting my diff out to be sent in for rebuild as it's got a broken stub axle/yoke. So my question is as long as I have to remove the mono spring is this a good time to replace it with one of the fiberglass units? If so then which one? My car is an L82 coupe and the metal spring was replaced not that long ago milage speaking. Attached pix are what the PO had the shop install.
Your thoughts/comments are much appreciated.
Old Jun 25, 2015 | 03:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you have a monspring, do you need to replace it? They're not supposed to wear out.
Old Jun 25, 2015 | 03:24 PM
MelWff's Avatar
MelWff
the 21-225 is a standard 9 leave replacement steel spring, it is not a mono leave spring, that term only applies to single leaf springs made from fiberglass. To determine which fiberglass spring to use you have to decide what you are going to do with this car and what your handling versus soft ride priorities are? You also have to use a decent gas shock absorber with the fiberglass spring.
Old Jun 25, 2015 | 03:38 PM
clwi's Avatar
clwi
I have this from Ecklers #: 25-122863-1 for my `72 454, and shock absorbers to match it.
Old Jun 25, 2015 | 03:46 PM
Basque32's Avatar
Basque32
MelWff,
Thanks for the reply & the schooling on the nomenclature (didn't know that ) and about the shocks which also need to be replaced at some point as well, maybe now?
Pretty much just trying to make the car a decent runner for weekends and such. Would like a little more performace from the CE replacement engine as it seems a little lethargic. The other thing is that the rear sits a little high which I understand I can lower the spring nuts some to help with that, got about a couple of threads left. Or I seen/heard folks use a 7 leaf spring as well, which I'm guessing would have the same effect?
Old Jun 25, 2015 | 03:53 PM
Basque32's Avatar
Basque32
Easy Mike,
Thanks for your reply. The former PO's paperwork might suggest that it was replaced due to the car was lower on the left side, not really sure, but if so may not have fixed the leaning issue as there are about a dozen shims on the left rear body mount to raise the body I assume?
Don't the metal spring fatigue over time/milage, cars got 84K.
Old Jun 25, 2015 | 04:14 PM
MelWff's Avatar
MelWff
Default Spring Type
Originally Posted by Basque32
MelWff,
Sounds like you dont intend to do Autocross or track days. With that in mind you want one of the lower rated springs on the links below. In addition you will need the 8" spring bolts and the gas shocks.
http://www.vbandp.com/auto-parts.htm...category_id=50
Old Jun 25, 2015 | 04:42 PM
Basque32's Avatar
Basque32
Thanks again. You are correct, probably won't ever seen the track. Thanks for the links. Looks like the 330# mono spring is a little less ($10 lol) and the Bilstein's are the sport model. I've read on here that some have said to get the HD's vs. Sport model. Thoughts?
To Mono Spring Question Suggestion
