73 base 350 rebuild
Old Jun 27, 2015 | 09:19 AM
FM73project's Avatar
FM73project
Default 73 base 350 rebuild
I'm preparing to rebuild my 1973 base 350. I would like to increase my horsepower without getting to far from stock. Any suggestions for example, changing the cam without affecting the vacuum? Pistons?
Old Jun 27, 2015 | 09:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Build an L-82 or an L-46. You can use all stock GM parts for either.
Old Jun 27, 2015 | 09:50 AM
FM73project
I was curious if a L82 head would work on the base 350.
Old Jun 27, 2015 | 09:56 AM
Gordonm's Avatar
Gordonm
Yes but there way better heads than the L82 heads. Go with a modern design head that flows better than that head. You can get iron or aluminum heads that are way ahead of the L82 head. If your not worried about original look put a mild cam on with good heads and a good intake with headers and good exhaust and you will think it is a different car. The cost to rebuild old heads is about the same for a decent set of aftermarket heads.
Old Jun 27, 2015 | 10:04 AM
toobroketoretire's Avatar
toobroketoretire
Have the machine shop convert it to a 383" so you'll get a good increase in torque but at the same rpm.
Old Jun 27, 2015 | 08:19 PM
LS4 PILOT's Avatar
LS4 PILOT
I support this post for your car.
How much HP .....do you really need ? The 350hp cam is a good upgrade , you need the older heads or diff pistons to get that compression punch cars after 1970 were missing. Even a set of 1970 350-300 hp heads had more compression.
The stock GM vintage type parts will make less power , but look more period correct and not turn off people looking for a more correct car when you sell.
At a certain point I feel throwing modern parts on starts to hurt the value of an old car ....it looses it charm.
Old Jun 27, 2015 | 08:43 PM
Cavu2u's Avatar
Cavu2u
FM73Project,
Is this a DIY project, or are you farming out the work?
How about keeping the original engine as is (unmodified), and dropping in a 383? You'll love the change in performance.
Steve
To 73 base 350 rebuild
