Okay, so there's a ton of threads on the hinge spring and bushing and what not, but my question is how the replace entire hinge? I have brand new lower and upper hinges for my 77. Please help
I ASSUME that you are not going to paint the hinges first.
You are aware that the shims and hinges is sealed in with a sealer upon installation so water does not migrate into your hinge post. So...you might need to get some sealant.
How skilled are you??? The reason I ask...so I do not get my head bit off...I need to know how to respond. So I do not get asked what a 'ratchet' is???
IS you car have ANY power going into the door for windows/alarm system etc???
DUB
Pretty skilled. No sealant on hand. The interior to this car is trashed, but from what I can see there is a cable in between up and lower hinges supplying power
