VIN code
Old Jun 28, 2015 | 06:17 AM
LennartB's Avatar
LennartB
Default VIN code
Hello
Here in Sweden "the big brother" have began to check the VIN code on the chassie/frame. I was told that I can find it behind the left rear wheel. I will be thankful for more information, perhaps a photo.
With best regards from Sweden Lennart B
-69 conv
Thank you for your help Wilcox. I have been busy for a time (work).
Old Jun 28, 2015 | 07:29 AM
BKarol's Avatar
BKarol
Good luck to them trying to read it
Old Jun 29, 2015 | 01:22 PM
LennartB's Avatar
LennartB
Many many many thanks that you spend time to answer my desperate question. I am greatful. I have restored the car for 3 years to completly original and it is time to hit the road .
Greatings from Sweden
With best regards Lennart B
Old Jun 29, 2015 | 02:25 PM
clwi's Avatar
clwi
Originally Posted by LennartB
Hello
-69 conv
On my -72 conv it is on the drivers side windscreenpost..
Maybe it is on the frame to ?
/Claes
Vasteras
Old Jun 29, 2015 | 03:11 PM
LennartB's Avatar
LennartB
/Claes
Vasteras
Det är den "vanliga VIN nummer placeringen" nu vill vara storebroder titta på det instämplade numret på ramen så det stämmer överens med numret på plåten på vänster stolpe, Nitade plåten. Sitter tydligen vid vänster bakhjul.
MVH Lennart B
Håller på att forska vill du hänga med ger jag dig fortlöpande info!!!
LennartB
Old Jun 29, 2015 | 03:47 PM
clwi's Avatar
clwi
MVH Lennart B
LennartB
Ska besikta i höst så det kan vara bra att veta.
/Claes
Old Jun 29, 2015 | 10:52 PM
gjohnson's Avatar
gjohnson
Bummer! You got big brother breathing down your neck too!
To VIN code
