Astro vent drain hose.
Old Jun 28, 2015 | 10:29 AM
Franks73's Avatar
Franks73
Default Astro vent drain hose.
On my 73, are a pair of Astro vent plenum drain hoses. The old ones were rotten. Thought I could just put some off the shelf hoses in their place. One end of the hose clamps onto a pipe, but how does the other end attach to the shield where the water drains out? Does the factory hose have a flaired end there?
Old Jun 28, 2015 | 11:41 AM
oldgto's Avatar
oldgto
Yes... a large flange... the tube goes in from the outside, with the flange ending up between the fiberglass wheel well and the outer trim ring....
Old Jun 28, 2015 | 12:55 PM
Franks73's Avatar
Franks73
Default Astro drains
OK, that makes sense, I thought I was scrapping off a gasket from behind the shield, it was part of the original hose. That diagram shows that aspect of the hose. A different one I saw did not. Thanks!
To Astro vent drain hose.
