Rear interior light stays on
Old 07-11-2015, 10:59 AM
moonsteel
Holley HP EFI w/TPI
Support Corvetteforum!
moonsteel's Avatar
Default Rear interior light stays on
Just finished replacing the rear harness on a 1974.
The rear interior light (back of the cargo area) stays on. Seems unaffected by doors being opened or closed.
Any idea why it's stuck on?
Old 07-11-2015, 04:13 PM
CanadaGrant
CanadaGrant's Avatar
Not sure about your year but on a 69, if the hood is open the rear compartment light will be on.
Old 07-12-2015, 09:18 AM
Bikersully
Bikersully's Avatar
Double check your headlight switch is not rotated to the fully counter clockwise. which turns that switch opn. If that is not the cause of the problem, check your door jam switches.
Old 07-13-2015, 11:37 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Checked, hood open or closed, made no difference.
Old 07-13-2015, 10:05 PM
gjohnson
gjohnson's Avatar
Had the same problem on mine once. Turned out to be door jam switch on drivers side was sticking. A little WD fixed it.
Old 07-14-2015, 01:26 PM
Easy Mike
Easy Mike's Avatar
Received 1,470 Likes on 1,249 Posts
Cruise-In II Veteran
Have you checked the headlight switch as Biker suggested?
Old 07-14-2015, 03:14 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
are your forward inside cabin lights on also? or just the rear ?
Caution, many times that rear bulb gets replaced with incorrect bulb.
that bulb should have two contacts on the bottom, not "1 contact"
To Rear interior light stays on
Quick Reply: Rear interior light stays on
