replacement front clip = fit issue
Does not surprise me.
Also...you have to take into consideration the brackets that attach to the outer bolts for your front impact bar. On how these pieces work in conjunction in how it aids in front end support.
Also...the reason I wait to bond in the front section of the inner skirts...is so when the front clip is on. I can set up and bolt up the lower valance panel and get it perfect. There is a lot more than meets the eye when putting a one piece front clip on a car like this. That is if proper fit is important. There are a lot of dynamics that come into play....and 'tricks' that if employed during the set-up...will allow the procedures performed after...actually work out well.
DUB
DUB
Any suggestions?
Any suggestions?
R
R
Since my last post on this thread, I gave up fighting with the mechanical fan hitting the shroud when the radiator was at the specified distance from the firewall drip edge. We installed dual electric fans and a new aluminum radiator. The rear hood hinge bolt holes are now at 43". (You will see a wire at the top of the fan shroud since we still have to drill and install our custom brackets)
Presently, the passenger side fender is overlapping the door significantly while the driver's side is short. I think that if I loosen the radiator brackets and pivot the radiator more toward the fire wall on the driver's side that might help. I have tried adjusting the frame extension in the same manner.
The aftermarket front clip still seems to be canted toward the passenger side.
If I attach the bumper extension, the bumper peak is canted to the left of the peak between the headlight openings.
This car was hit in the driver's side nose before I bought it, but I paid to have the frame straightened. The frame shop only had to straighten the frame extension. It is possible that the extension is still tweaked but I believe the front clip fit more square to the doors when I first dry fit it years ago. I also measured the frame years ago and it appeared to not be bent.
Also does anyone have a measurement from the top of the wheel to the lower edge of the fender (front). I am using the stock springs.
Any suggestions as usual would be appreciated. I can take more photos with the clip removed tomorrow.
4rensic22
I really like this cats down to earth take on it
http://www.corvette-restoration.com/...lacement_1.htm
4rensic22
Good luck!
RVZIO
I would like to run some small flares as well. Once again I wonder about the replacement panels that already have flares on them.
I have seen forum members spend many hours trying to get an aftermarket part to fit.
I hope this works out for you.
R
I put yellow masking tape along the peak in the nose and it seems to line up with the peak on the hood now.
We also have to adjust the height of the front clip to the hood.
I am more confident that we will get this front clip installed now. Hopefully we will be able to align the front end afterwards.
Will post photos later today.
