Which Solid Motor Mount Frame Bolts?
Old Jul 16, 2015 | 03:44 PM
dgheinen's Avatar
dgheinen
Default Which Solid Motor Mount Frame Bolts?
Got myself some Moroso solid motor mounts, with new hardware from the mount to the block, but I'm having trouble finding the correct ARP frame bolts, the through bolts. I've found 130-3105, but I believe they're only for the rubber mounts. If someone can help, that'd be greatly appreciated!
Thanks in advance,
Damon
Old Jul 16, 2015 | 04:38 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Hopefully you have Moroso #62530 mounts, which directly replace the OEM mounts in all SB or BB C3 applications. The stock thru bolts work fine.
Old Jul 16, 2015 | 04:42 PM
dgheinen's Avatar
dgheinen
Okay, perfect. Yeah I got 62530 mounts. I was just hoping to get some new ones, just for "feel good" security. I might just try the local parts store.
Old Jul 17, 2015 | 02:48 PM
toobroketoretire's Avatar
toobroketoretire
I clearly remember seeing Chrysler products in the 1970's that had short 1/4" cables running from the frame to the left side of the engine block to prevent the engine from lifting IF the motor mount failed.
Rather than using so-called "locking" mounts on my 454" I drilled a 3/8" hole thru the middle of the left-side motor mount then put a 3/8" bolt and self-locking nut on it. If for some reason the mount failed the bolt would prevent the engine from lifting.
Old Jul 17, 2015 | 02:58 PM
BOOT77's Avatar
BOOT77
I just got some grade 8 and jam nuts form the local hardware.
To Which Solid Motor Mount Frame Bolts?
