radiator seal ?
Old Jul 29, 2015 | 05:00 PM
dynaj's Avatar
dynaj
Default radiator seal ?
Quick question for all you c3 guru's, I bought my wife a 79 the other day and it ran great (minus the trailing arms..) until we got on the freeway and I got the common overheating as I go faster (approaching the red marker) so after using the search feature I discovered that there where suppose to be seals around the radiator so I ordered some and now the big question is do I need to remove the radiator to install them? I'm going to flush the radiator so I was hoping that I wouldn't have to pull it. Can someone confirm if I need to pull it. I will also be putting in a new thermostat and lower hose as mine can be collapsed with 2 fingers I'm assuming that's bad as well. Thanks for all your help.
Old Jul 29, 2015 | 05:40 PM
SH-60B's Avatar
SH-60B
yes, the radiator needs to come out. I don't have those seals and mine runs right at the thermostat setting, but I have a DeWitts' with e-fans. I had the same problem as you do with the original radiator though. It wasn't the seals in my case, it was the missing air dam in front, without that you won't get enough airflow at freeway speeds to keep it cool. Is yours on there?
Old Jul 29, 2015 | 06:13 PM
dynaj's Avatar
dynaj
Poop!! lol. Yes the air dam is there but it has a split (small) in the middle and I have all intentions on replacing that too. After the 2000.00 trailing arm replacement my wallets a little light so I'm trying to fix the stock stuff before I jump on a dewitts radiator but I have a feeling that I'll be putting one in soon...
Old Jul 29, 2015 | 07:38 PM
SH-60B's Avatar
SH-60B
It's not hard to take out. The clutch fan has to come off 1st, then the shroud, then the radiator.
Old Jul 29, 2015 | 07:47 PM
augiedoggy's Avatar
augiedoggy
If your on a budget you dont need a dewitts if you just want functionality... I replaced my original rad with an aluminum 3 row champion rad for $200 and I didnt install the seals the temp hold fine for which ever thermostat I use.. (It took three thermostats before finding one that actually worked correctly btw so make sure thats not your issue.) and I have a mild cammed 355 with side pipes and an auto trans so it gets toasty under the hood...
Old Jul 29, 2015 | 07:54 PM
BKarol's Avatar
BKarol
If you have this extension then the split belongs there. If you don't have an extension check with Willcox as he mentioned wanting to produce them. This is the only part that dropped my temps on the highway:
Old Jul 29, 2015 | 07:58 PM
vbgod1's Avatar
vbgod1
While I was in the area replacing my front end parts, I read about the seals, and noticed I had none. Went to hardware store and bought one of those pipit insulators that looked like a pool noodle that's hollow and split. Put it between rad and support, then bolted rad on to seal gap.
Old Jul 29, 2015 | 08:58 PM
76CSRvette's Avatar
76CSRvette
pics?
Old Jul 29, 2015 | 09:46 PM
dynaj's Avatar
dynaj
I looked at these, they have them in stock & most likely going to order one.
Old Jul 29, 2015 | 09:48 PM
dynaj's Avatar
dynaj
The thermostat was going to be the first thing I was going to try, I think it had a 195 stock? If the radiator has to come out then I'm going to replace it just for peace of mind.
Old Jul 29, 2015 | 10:20 PM
augiedoggy's Avatar
augiedoggy
I actually did the same across the top of my rad but I didnt need to unbolt anything to instal... it fills the gap between the support and radiator. I still have my original copper harrison unit sitting in the garage .. Since I was replacing the rotted mount as well as the engine I figured for $200 I would replace the radiator with an aluminum one for piece of mind also.. it looks, fits and works well. I use a 180 stat now... There are only two manufactuers of these thermostats left that I could find... most are made by the same company including mr gasket and stant and robert shaw I believe... Robert shaw made thier own until recently jumping on the china bandwagon from what I've read... I tried 3 high flow ones and ended up finding a different model stant that actually opened reliably at the same temp... it was the old one I pulled out of my dodge truck years ago because the 180 stat messed with the computer A/F and mpg.
Old Jul 29, 2015 | 10:55 PM
7T1vette's Avatar
7T1vette
The front spoiler is important, as are the radiator seals. But, if the metal spring inside the lower (suction) radiator hose has turned to rust, it can't do the job that was intended and the hose may be collapsing as the rpm's go up (and closing down the supply of cool water). When cool, squeeze the lower radiator hose. If you can squeeze it down, there is no spring left inside.
Old Jul 30, 2015 | 08:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...If the radiator has to come out then I'm going to replace it just for peace of mind...
Why not have your stock radiator cleaned? No need spending money on aftermarket parts you may not need.
Old Jul 30, 2015 | 09:33 AM
dynaj's Avatar
dynaj
The lower radiator hose is shot, and I am going to have the original radiator dipped and cleaned. I'm wondering if I should just replace the water pump while I'm at it? It's not leaking but with 70,000 on the clock I'm thinking it might have some corrosion in it but I hate to change something that isn't broke!!
Old Jul 30, 2015 | 09:36 AM
thegazman's Avatar
thegazman
Default thegazman
On a 79 have someone help you slide the radiator up and out. Then you can remove the shroud out past the a-arms. The shroud will not clear the a-arms with the radiator installed.
Old Jul 30, 2015 | 10:54 AM
1Hotrodz's Avatar
1Hotrodz
Thats exactly what happening. Only part of the problem though, do the seals and the spoiler. Flush the Rad. too and you should be good to go!
Old Jul 30, 2015 | 12:09 PM
dynaj's Avatar
dynaj
Thanks for the heads up!!
To radiator seal ?
Old Jul 30, 2015 | 12:30 PM
CanadaGrant's Avatar
CanadaGrant
This is a problem that is overlooked and is probably a factor as you say it gets hotter the faster you go. If the spring inside the lower hose is collapsed from rust allowing the hose to flatten out with engine rpm those are the symptoms you will get. I doubt you will get overheating at highway speeds due to the lack of a few rad seals....
Good luck!
Old Jul 30, 2015 | 01:17 PM
dynaj's Avatar
dynaj
I think the easiest way and the smartest way to is to eliminate the easy stuff first. This weekend I'm going to 1. Flush the radiator
2. Put new upper & lower hoses on. 3. Put a new thermostat (should I go with the O.E. Temp? I believe it was a 190. It's a stock motor) put the top radiator seals on. Test drive it and see if it gets hot, if it does then I'm pulling everything and going back with a new radiator and high flow pump..this is my wife's toy so I'm trying to get it up to par so she can run around town without the fear of overheating. By the way the lower house is shot!!!
Old Jul 30, 2015 | 01:45 PM
BEVO76's Avatar
BEVO76
I have a Champion 3 Row as well. Best $200 I have ever spent. Love the rad and the temp starys right at 185 degrees. Prior to that with the old brass rad I was running about 210-220. So a pretty huge improvement.
