I believe the controls of the vintage air in the center console will be changed from vacuum to electronic controls. As such the vacuum ports will no longer be used and most likely plugged up. What will happen the the rear flaps (Astro Ventilation) in the storage compartment in a '75 coupe non A/C car?
In other words since they operate on vacuum from the center console controls, once the controls are switched over, how will they operate?
Richard454, I appreciate the reply, and even though you feel it's simple I don't know how to set up the operation of the rear vent via the Vintage Air controls
The original thumbwheels control the Vintage Air AND the rear door.
Here's how-
On the right- there is a vacuum valve ("B" in diagram). The top hose("F") goes to engine vacuum and the bottom hose("H") goes to the back vacuum actuator("E") located at the rear deck vents. The center connection is not used.
The valve on the left ("A") is not used at all- as the Vintage Air electronic slider interface will handle those controls.
The right wheel-
When it is all the way to the top- door is open- as there is no vacuum because the valve is closed- turn the wheel all the way to the bottom- valve opens and vacuum closes rear vent doors.
