Bilstein HD or Sport
Old Aug 12, 2015 | 10:07 PM
ctuinstra's Avatar
ctuinstra
Default Bilstein HD or Sport
I really hate the descriptions that the manufactures use on the products. There is no real meat there to help make a decision. Does anyone know more about the compression and rebound characteristics between the two? I assume the Sport has more compression and rebound then the HD.
Old Aug 12, 2015 | 10:18 PM
jb78L-82's Avatar
jb78L-82
I have both...hd in front with 550 springs and sports (30% stiffer than hds) in the rear with a 360 composite spring...perfect match
Old Aug 12, 2015 | 10:21 PM
C3Hawk's Avatar
C3Hawk
I can totally relate to this issue. I had to compile a lot of sources to reach a decision. Never found specific numbers for the 2.
Having said that, I went with the HDs all around. These with my 330# composite spring give me a ride I am happy with.
Old Aug 12, 2015 | 10:35 PM
Zorro O's Avatar
Zorro O
The HDs ride much better on the street. They are firm but will not beat you up. The sport are supposed to be better for the track according to thier phone rep. I have put HDs on several cars and never regretted it. It is really confusing the way they are named. I finally called them and asked.
Old Aug 12, 2015 | 10:41 PM
ctuinstra's Avatar
ctuinstra
In the off-road world, they scrutinize every aspect of the shocks and suspension. As soon as you go to on-road vehicles, the best information you are provided from shock manufactures are "Smooth ride...". There are many factors one should consider when purchasing shocks such as you guys mentioned the spring rates, BB vs SB, driving style among other things.
My wife's truck OEM shocks were leaking and gone in the first 30K, rode like crap bouncing all over the place. Same issue here, you just buy the first set you find for the best price. They worked better then nothing, but I hate the rebound in the new shocks. My 1000' gravel driveway is nothing but a washboard because of the *** end of that truck and the terrible shocks put under a bed that also are made for some completely different vehicle.
Old Aug 13, 2015 | 10:39 AM
pws69's Avatar
pws69
Sports here on my 69 for several years. Still like them a lot - I don't think they are that harsh on the street (I never do track) - but I do prefer a stiffer ride.
Great shocks!
Old Aug 13, 2015 | 10:45 AM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
I have used both Sport & HD's on my 82.....IMO Sport as mentioned or implied above is not suited for the street, especially if used as a "dd" like I have. I ended up selling them to another member to help offset the cost for the HD's which I have had on for the last few years. Very happy with them and they handle just as good as the Sports IMO on the road. I never thought to use a combination of the two as "as jb78L-82" has, and depending on your use may be a good combo for you also. But for me the HD's are just fine......Tom
Old Aug 13, 2015 | 10:53 AM
74 LS4-454's Avatar
74 LS4-454
This may also help you out, was posted when we were trying to find more info on the shocks....
Quote:
Originally Posted by dave pawlowski
This is from Bilstein:
The lengths are the same.
The damping rates are:
front HD 1525/855 (rebound rate/compression rate, in newtons)
front sport 1810/1050
rear HD 2595/865
reat sport 2725/980"
that was really a good find....
Old Aug 13, 2015 | 03:07 PM
jb78L-82's Avatar
jb78L-82
I don't race my 78 but found the HD's with the rear composite 360 spring was too bouncy and since my front springs are 550's, I felt that after driving with the HD's in front that further damping was not needed, so left the HD's in place and sold my Bilstein rear Hd's to a fellow forum member with 2,000 miles on the shocks. With that said the hybrid combo of HD's and sports worked perfectly on my C3. It depends on the car, but my HD/Sport combo does NOT ride harsh at all on the street and is firm but very comfortable. My Chrysler 300 with stock springs and 245/55/18 ZR tires with Bilstein HD's rides MUCH harsher than my 78 Bilstein Hybrid shock combo. My 94 Mustang GT with stock springs and Bilstein HD's rides softer but my stock C6Z06 with stock suspension as well as my 12 Lexus IS350 F sport with stock suspension both ride harder than my 78. Unfortunately, I think that hitting the sweet spot for any one particular driver depends on driving preference characteristics and the particular car, even one C3 to another.
Old Aug 13, 2015 | 03:49 PM
bluedawg's Avatar
bluedawg
sport and you be happy.
Old Aug 13, 2015 | 05:07 PM
jb78L-82's Avatar
jb78L-82
rear HD 2595/865
This is really good info and it appears that the difference between sport and HD's are much greater for the front shocks than the rears. The rear Sports are 13% stiffer than the HD's on compression but only 5% stiffer on rebound according to the numbers. Bilstein use to advertise that the Sports in general (not C3 specific) are 30% stiffer than the HD's...appears not to be the case for the C3's and in my personal experience with the rear Sports versus the HD's...the sports are noticeable firmer but NOT overwhelmingly so which the numbers support. My experience has been that with 550 front springs, The HD's are more than adequate. I would imagine that a C3 with OEM base springs (very low rate springs) would greatly benefit form the Bilstein sport for those that want to inject some real sport into their C3.
Old Aug 14, 2015 | 11:59 AM
74 LS4-454's Avatar
74 LS4-454
Glad you like the info, it helped me make my decision at the time.
To the OP....All-in-all, choosing shocks is just like anything else out there, its basically a trial & error period. Granted we all can't go buy different types of shocks just to try and hopefully sell them if they don't work out. I was fortunate to be able to that with my 82. Remembering that what works for one doesn't mean it will work for you.
Taking into consideration what your use for your C3 will help you determine what will be the best shock for your type of driving. Mine being my "dd" and driving it at least 2 hours per day, I tried to find the balance between ride comfort & handling. The HD's do that for me, but on rougher side roads you do feel it somewhat. On the highway, on & off ramps, I fell you can't beat them.....as the Vette is firmly planted on just about any ramp or curve I can find. Ride is great on the highways and local good roads.
But again to the OP, if your C3 is for different purposes and only slightly used, you may want the Sports instead of the HD's. It all depends on what your preferences are and how you will be driving your C3.
Also remember that tires and suspension pieces also play a part in the ride and comfort that you would expect from your Vette...Good Luck!!!
Old Aug 14, 2015 | 12:21 PM
ctuinstra's Avatar
ctuinstra
I appreciate the information on them!! That is what I'm looking for. It give me a better understanding of the differences between the two. Why can't the manufactures posts those numbers for all their products? I assume it's so the comp doesn't just copy their product. I will probably start out with the HD since I just cruise with it. But it's good to know that I can go up.
To Bilstein HD or Sport
