69 Vette re-assembling manual strg wheel issues
Old Aug 13, 2015 | 05:53 PM
u00ras3's Avatar
u00ras3
Default 69 Vette re-assembling manual strg wheel issues
Trying to re=assemble the manual steering wheel on 1969 corvette roadster. I have replaced the broken ignition tumbler and trying to reassemble the steering wheel, but having problems with the lock ring. I can't compress spring and plate assembly far enough to re install the lock ring. The compression lacks 1/8 inch of reaching groove for lock ring. I have had this assembly apart 4 times resulting with same issue. I woud appreciate any suggestions. Thanks in advance.
Old Aug 13, 2015 | 06:48 PM
mysixtynine's Avatar
mysixtynine
Are you using the tool to compress the lock ring down?
I got this one at Sears 41834 a long time ago..
Old Aug 14, 2015 | 12:58 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
what he said, must have.
Old Aug 14, 2015 | 01:29 PM
toobroketoretire's Avatar
toobroketoretire
I made my own tool and with that tool its as easy as it can be.
Old Aug 14, 2015 | 10:38 PM
Jim Shea's Avatar
Jim Shea
Your problem is that the upper steering shaft telescopes as you attempt to compress the locking plate.
When you tighten the "star screw" this prevents the upper shaft from telecoping. However, most tools interfere with the star screw. Use a 5/16-18 set screw or a #20 Allen Screw in place of the star screw.
Jim
Old Aug 15, 2015 | 02:06 AM
mysixtynine
Hey Jim
My tool cAme with a set screw ... I've only had non tilt columns... And pics of this set screw in action?
Old Aug 15, 2015 | 08:30 AM
Jim Shea's Avatar
Jim Shea
Originally Posted by mysixtynine
Hey Jim
Standard (non-adjustable) steering columns do not require a "star screw" or set screw since the upper steering shaft does not telescope. Here is a picture of the upper steering column parts.
http://jimshea.corvettefaq.com/wp-co...trpage1pdf.pdf
Hopefully it has sufficient information to help you.
Jim
To 69 Vette re-assembling manual strg wheel issues
