Figure Eights After Changing Rear End Lube
Old Aug 18, 2015 | 09:35 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Notice you haven't seen me post much lately. Tired of the same issues voiced here.
Old Aug 19, 2015 | 06:39 AM
toobroketoretire's Avatar
toobroketoretire
Default Question Of The Day
Here's the question of the day: What happens if you DON'T do figure eights after changing your rear end lube?
Old Aug 19, 2015 | 07:17 AM
Big2Bird's Avatar
Big2Bird
You make sure you have the last word in a thread about it?
Old Aug 19, 2015 | 07:18 AM
bashcraft's Avatar
bashcraft
Originally Posted by DUB
I FEEL your PAIN. Explaining the dynamics of a system or component to a degree that a person would have to be an imbecile and not understand it...and still the information gets challenged.
Wow! Déjà vu.
Old Aug 19, 2015 | 07:19 AM
redvetracr's Avatar
redvetracr
hey Bird, who_ does_ this_ guy_ remind_ you_ of??????
Old Aug 19, 2015 | 07:23 AM
Big2Bird's Avatar
Big2Bird
I can't help but feeling he is his uncle.
"Engine builder, not professionally of course."
Old Aug 19, 2015 | 08:53 AM
toobroketoretire
My question was "what if you DON'T do figure eights"? Give me an answer that makes sense.
Old Aug 19, 2015 | 10:26 AM
DonnieP73's Avatar
DonnieP73
I really hate to enter this, but this is my own personal experience.
After setting up for over 20 years and a 3 year restoration I got my 73
back on the road again. I started having a popping from the rear end when I
creeped ahead from a stop. Ordered the additive and got new gear oil,
but I thought I would just try the figure 8's first.
Sure enough after doing them, the popping stopped and hasn't returned
again.
So there it is for what it's worth.
Donnie
Old Aug 19, 2015 | 10:42 AM
bashcraft's Avatar
bashcraft
again.
Donnie
It would've stopped after some normal driving too, just may have taken a bit longer.
I've changed the rear end and gear oil in my '69 3 times in the 36 years I've owned it. Never once did I use the GM additive, I always used the gear oil with the additive already in it. Never once did I have any popping or clunking or whatever supposedly happens.
Old Aug 19, 2015 | 12:13 PM
63mako's Avatar
63mako
In a new build the Friction modifier is not between the discs which are tightly squeezed together. That popping noise is those discs seizing and binding on each other. They are thin and can crack, break or gall, transfering material one to the other, have opened them up on multiple occasions to find exactly this damage. On a change it allows the fresh lube with the proper ratio of modifier to lube to get between the discs warding off potential damage (see above) from not enough modifier in the old lube or broken down lube. A better question is why would you go against conventional wisdom and common sense to argue about it?
Does that make sense to you?
Old Aug 19, 2015 | 12:18 PM
bashcraft's Avatar
bashcraft
Why would the rebuilder not use oil with the modifier added when assembling the unit?
Old Aug 19, 2015 | 12:25 PM
tracdogg2's Avatar
tracdogg2
It usually comes down to one of two things: cheap or lazy.
There is absolutely no reason NOT to assemble the clutches with a mix of lube and additive.
Mike
Old Aug 19, 2015 | 12:46 PM
  #33
lionelhutz's Avatar
lionelhutz
Originally Posted by tracdogg2
If you drain gear lube with modifier out and install new fluid with modifier why would you even need to work it in? I don't quite understand your question. If the clutches aren't popping from lack of modifier in the old lube, you don't need to work in the new lube. Because there ain't no problem.
If the clutches are popping with the old lube it's because of lack of friction modifier on the clutches. That's why they are popping. They are sticking to each other. The lube with friction modifier needs to be worked into the clutches. Hence figure 8's.
Really? On a 90 degree turn in town the outer wheel is going to rotate a dozen times more than the inner wheel. How big are the streets in your town?
Exactly what he posted here. If the clutches are grabbing then do some circles to work in the new fluid instead of driving for days or weeks before it stops grabbing.
WTF is so hard about driving to the closest parking lot and doing a few circles in each direction....
The better question of the day is why aren't these idiotically stupid threads belong in C3 General with a poll attached where they belong?
Old Aug 19, 2015 | 03:22 PM
  #34
toobroketoretire
Because the job has already been done by the time you get to the parking lot.
But my question was "What happens if you DON'T do figure eights?
Old Aug 19, 2015 | 03:23 PM
  #35
toobroketoretire
Because the "working it in" job has already been done by the time you get to the parking lot.
Old Aug 19, 2015 | 03:39 PM
  #36
tracdogg2's Avatar
tracdogg2
Same thing as all of your replies. It makes a lot of irritating noises and annoys the crap out of everyone involved.
Old Aug 19, 2015 | 04:21 PM
  #37
SH-60B's Avatar
SH-60B
63 Mako already answered your question, that should be enough, but look at it from a "professional" point of view. Say you did a rebuild and didn't bother to do the figure eights. Customer picks up the car all happy but comes back five minutes later asking WTF did you do to my car, whats all these noises? I'd rather take the car for a figure eight test drive than deal with a pissed off customer who may not ever come back, or talk trash about your shop.
To Figure Eights After Changing Rear End Lube
Old Aug 19, 2015 | 04:35 PM
  #38
Big2Bird's Avatar
Big2Bird
All you HAVE to do is pay taxes and die. All else is an option.
BTW, this thread is taxing, and I wish it would die as well.
Old Aug 19, 2015 | 06:29 PM
  #39
DUB's Avatar
DUB
Mike
100%
Those that KNOW....KNOW to do this step...so any chance of potential damage is lessened....and mentioned by 63 Mako and tracdogg2.
I am NEITHER cheap or lazy.....and regardless of the type of rebuild to a differential. I personally do the road test to 'break-in' the ring gear (if replaced) and or get the clutches lubed so there is no problem. I will do whatever it takes so I do not have to re-visit a repair.
Nobody is perfect. I KNOW I have been wrong and ADMITTED IT...that I WAS WRONG.....but at some point....this HAS to sink in and make sense. If not...than this is ridiculous...much like trying to lead a horse to water that does not want to drink.
DUB
Old Aug 19, 2015 | 07:10 PM
  #40
V4motorsports's Avatar
V4motorsports
Just replaced my fluid and thought...why not do the figure eights, whats it going to hurt?
My grabbing/clunking is now gone.
Russ
