Weird Steering problem
Old Aug 29, 2015 | 12:27 PM
haarvik's Avatar
haarvik
Default Weird Steering problem
Since I can now drive my Vette on the road, I have noticed something weird. Starting out my steering wheel is straight. If I take right turns it then is about 1/4 turn to the right. If I turn left, it is then 1/4 turn off to the left. It's almost as if something is skipping gears, but it turns just fine. Is there something that may be loose causing this?
Old Aug 29, 2015 | 12:57 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
What year is your car?
Does it have a manual steering box......or power steering?
Also.......have someone sit in the driver's seat with the hood open.....let them turn the steering wheel VERY slowly one turn to the left.
Does the steering shaft that enters the steering box turn the same amount as the steering wheel?
Now......turn the steering wheel back to center..........let them turn the steering wheel VERY slowly one turn to the right.
Now......Do the same tests above while watching the Pitman arm that is located on the bottom of the steering box......what are the results for the Pitman arm tests?
There are other visual tests that can be done for the lower linkage, but the above tests need to be done first.
Post your results here (a video of each test would be good, but not necessary)
Old Aug 29, 2015 | 01:01 PM
haarvik's Avatar
haarvik
It's a 1981. I have power steering.
Old Aug 29, 2015 | 08:33 PM
BB2B's Avatar
BB2B
does the car still track straight after the turn or will it drift in the turn direction?
Old Aug 29, 2015 | 10:05 PM
hugie82's Avatar
hugie82
Sounds like the rag joint
Old Aug 30, 2015 | 11:21 AM
doorgunner's Avatar
doorgunner
If it IS.......he'd better replace it NOW!
Old Sep 4, 2015 | 02:45 PM
haarvik's Avatar
haarvik
Ended up just being an alignment issue. Problem solved.
Old Sep 5, 2015 | 12:09 AM
7T1vette's Avatar
7T1vette
No "alignment problem" would do what your steering is doing....unless there were bolts/nuts left loose. Your ragjoint is probably "toast".
To Weird Steering problem
