harmonic vibration
Old Sep 1, 2015 | 08:34 PM
74kelley's Avatar
74kelley
Cruising
Default harmonic vibration
I just picked up a 76 c3, it has a vibration when you put power to it if you hold a steady speed, the vibration gets worse, ,,I the universals have been changed, we are putting it up on a lift tomorrow, is their anything I should be looking for?? thanks its bone stock
Old Sep 1, 2015 | 10:34 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
More info.
Stick or auto?
Does it shake when you rev it in neutral?
Any shake when accelerating or decelerating?
Check for play in the output yoke on the tranny and input yoke on the rear end for starters.
Old Sep 2, 2015 | 07:04 PM
hugie82's Avatar
hugie82
Get the car vibrating and then Put the car in neutral and see if it's the engine.
Old Sep 2, 2015 | 08:25 PM
74kelley's Avatar
74kelley
Cruising
Originally Posted by claysmoker
More info.
Stick or auto?
its an auto, the engine is smooth ,accelerating and when you hold steady, at 40-45 mph when it viberates shakes, ,it has new ujoints, when we jacked it up the pas side tire drooped lower than drivers side and the spring hanger bolt rubbed on wheel--it has had a 4wheel alignment, we asked the drive shaft people could they be out of wack?
Old Sep 2, 2015 | 08:28 PM
74kelley's Avatar
74kelley
Cruising
engine smooth,,wonder if the 1/2 shafts or the wheel bearings need attention,we are still looking
Old Oct 5, 2015 | 09:50 PM
74kelley's Avatar
74kelley
Cruising
More info.
Stick or auto?
its the harmonic balancer,, its loose and the rubber is falling off,,so we are going to replace it-thank you for your help
Old Oct 5, 2015 | 09:53 PM
claysmoker's Avatar
claysmoker
Glad you found it. I'm surprised you didn't detect it when revving the engine in neutral. Let us know how it turns out.
Old Oct 5, 2015 | 09:59 PM
74kelley's Avatar
74kelley
Cruising
Old Oct 12, 2015 | 03:42 PM
gearbreaker's Avatar
gearbreaker
When you're done with the balancer you might want to get the exhaust pipe off the crossmember hole. The exhaust resting on the crossmember will cause vibration also.
Old Oct 12, 2015 | 05:11 PM
74kelley's Avatar
74kelley
Cruising
Originally Posted by gearbreaker
when you're done with the balancer you might want to get the exhaust pipe off the crossmember hole. The exhaust resting on the crossmember will cause vibration also.
To harmonic vibration
