Carb. Suggestion ;)
Old Oct 10, 2015 | 04:19 PM
Cattiva73's Avatar
Cattiva73
Default Carb. Suggestion ;)
Im sure it has been covered before..but my application is a little different:
my '73 Corvette has a Chevy 402 no modifications , MSD Distrib. with MSD Box. The vacum is ok ..not great.
I drive it to car shows and occasional trips.
Which carburetor should I buy:
Quick Fuel 600cfm (Quick Fuel SL600VS)
or
Road Demon 625cfm (4282010VE)
I tried a QF 600cfm and it runs great...just a little hesitation when going from stopped... if I slowly push the gas paddle All is good..only if I really push it ..it hesitates at first and then it goes
I was thinking 650cfm may resolve the issue.
I believe 750 cfm is too much for my engine...any suggestion on the two brands and cfm I should go with?
Old Oct 10, 2015 | 05:19 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Rebuild a Quadrajet for it. It will get better fuel economy and should run great.
What carb is on it now? You probably need to tune your existing carb. Are you running vacuum secondaries?
Old Oct 10, 2015 | 05:38 PM
diehrd's Avatar
diehrd
That hesitation is not a carb problem it is a tuning issue with the carb .
Old Oct 10, 2015 | 09:44 PM
REELAV8R's Avatar
REELAV8R
Sounds like an accelerator pump problem. Either too much squirt or not enough.
Old Oct 10, 2015 | 10:04 PM
COOLTED's Avatar
COOLTED
X3
Old Oct 10, 2015 | 10:05 PM
Cattiva73's Avatar
Cattiva73
Could you be more specific on the tuning? Thanks
Old Oct 10, 2015 | 10:14 PM
REELAV8R's Avatar
REELAV8R
I've never tuned one, however I found this on quick fuel's site.
http://www.quickfueltechnology.com/t...e-bog-the-boot
Old Oct 10, 2015 | 10:49 PM
Cattiva73's Avatar
Cattiva73
Thank you! Very helpfull.
Old Oct 10, 2015 | 11:45 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I can tell you a 750 is NOT too much for it....
600's are for very mild 327/350's....
JIM
Old Oct 11, 2015 | 12:13 AM
7T1vette's Avatar
7T1vette
750 cfm carb is not too much for it if the carb is a Quadra-Jet or a square-bore carb with vacuum operated secondaries. 750 cfm is probably too much for it if it has just a 'dumper' secondary on it.
Q-Jet secondaries regualte the flow into the engine depending on the engine's capabilities...not the carb's. A vacuum secondary system attempts to duplicate that approach. Otherwise, the carb's A/F flowrate needs to match what the engine requires...or you get lean or 'fat' conditions at WOT.
But, just purchasing ANY new carb is not the solution; it's just the first step.
Old Oct 11, 2015 | 07:14 AM
96 lt-4's Avatar
96 lt-4
A well tuned quadrajet or holley 750 vacuum secondary would be the best choice for max performance.If they are setup correctly there will be no drive ability issues.
Old Oct 11, 2015 | 07:48 AM
GUSTO14's Avatar
GUSTO14
It would probably be a bit more helpful to know more about your current setup. Based on your profile, I take it you have a 402 Big Block, correct?
What trans and rear gears are you running?
What cam and intake manifold are you using right now?
Good luck... GUSTO
Old Oct 11, 2015 | 10:11 AM
Little Mouse's Avatar
Little Mouse
Have not owned one but quick fuel seems to have established a good rep on carbs if your going to buy a new carb.
A 402 big block even a stock one needs a 750 size carb. Think of how much more air the heads and intake manifold can flow on it along with its exhaust flow in comparison to any factory SBC head and intake manifold at all rpms levels you drive the car at from idle on up. Using to small a carb on it does nothing for you but hurt you. Look into a vacuum secondary from quick fuel 750 for what you describe you want to do with your car. Quick fuel seems to give a lot of the more fine tune adjustable in there carb for there cost.
If you want to mess with an old carb there would be nothing wrong with using a 750 Q-jet on it.
Old Oct 11, 2015 | 11:22 AM
diehrd's Avatar
diehrd
Your idling off the transition slots , that causes the issue you describe .. I would also suspect that when you try to adjust the idle A/F you get little or no change ..
If I am on target ... Set the transition slots and adjust curb idle off the 2 back butterflies using an allen wrench ( It may need to be ground to a flat head I forget ) , it is sort of tricky but easily doable
Old Oct 11, 2015 | 01:40 PM
Cattiva73's Avatar
Cattiva73
when I push the gas paddle the carb. pops and hesitates a split of a second...I adjusted the acceleration pump spring and it seems better..stil pops!
Old Oct 11, 2015 | 02:08 PM
Cattiva73's Avatar
Cattiva73
Right now I have a QF 600cfm?..it pops!
Im thinking about changing the main nozzle from a 31 to a bigger 33 or 35 ??
Old Oct 12, 2015 | 06:36 PM
Silvertone's Avatar
Silvertone
Are you using the vacuum advance on a full vacuum port? Also, can you describe the ignition timing you have?
To Carb. Suggestion ;)
