Steering Knuckle
Old Sep 11, 2015 | 08:02 AM
mk8035's Avatar
mk8035
Default Steering Knuckle
Have a 76 Vette. Looking all over the internet to find a picture or Diagram on installing the Steering Knuckle Arm and Steering Knuckle. Any help would be greatly appreciated
Old Sep 11, 2015 | 12:03 PM
tyancey00's Avatar
tyancey00
http://www.autotraderclassics.com/im...1714/71714.jpg
check this guy. they have a lot of info...
Old Sep 11, 2015 | 01:07 PM
redvetracr's Avatar
redvetracr
I can`t help with a diagram but if you bolt up the top of the caliper bracket the rest should be easy to figure out.
Old Sep 11, 2015 | 03:29 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
This is the best look I can offer.
Old Sep 11, 2015 | 05:50 PM
mk8035's Avatar
mk8035
You did it that is what i needed THANKS
Old Nov 18, 2015 | 01:45 PM
Jason Burt's Avatar
Jason Burt
I'm gonna jump in on this instead of starting a new thread... are there two mounting positions on the steering knuckle? That one looks like a second hole but it looks to not be drilled through... my car of course is all greasy and dirty under there and i haven't looked yet to see if there are two mounting holes or just one.
Old Nov 18, 2015 | 02:27 PM
Sigforty's Avatar
Sigforty
There are two holes. The outer one is plugged with a rivet. My car is a power steering car and used the inside hole.
I am not sure, but the outer hole maybe for non-power steering vehicles.
Old Nov 18, 2015 | 02:49 PM
Alan 71's Avatar
Alan 71
Hi,
Sig, your right.
Cars without p/s have the tie-rod end in the rear hole.
Cars with p/s have the tie-rod end in the forward hole and at least 'originally' had a large aluminum plug, (looked like a rivet), in the rear hole.
Regards,
Alan
To Steering Knuckle
