Low Coolant Temperature - is this normal??
Old Oct 13, 2015 | 09:10 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Low Coolant Temperature - is this normal??
Yesterday, I swapped out my temperature sensor as I thought that the sensor in the car didn't have the accurate reading as it was reading pretty low. The car would not even get to the 1/4 line on the temperature scale.. Only on a very hot day in city traffic, it would be solid on that line.. Otherwise, the coolant temperature would show below that first mark.
So, after swapping out the sensor for a brand new one that was supposed to have the "correct" reading, the reading was exactly the same as with the sensor that I removed...
Is this normal for a fairly stock 327/300 (mild cam & Team G intake)?? The car does have a aftermarket aluminum direct replacement (probably DeWitt) radiator. Other than that, the cooling system looks stock.
What temperature does the 1/4 mark represent?
I've never had a C3 before that would run that cool, even with removed thermostat..
Old Oct 13, 2015 | 09:24 AM
Bloodzone's Avatar
Bloodzone
I think 1/4 mark is around 160. Have you checked your thermostat? Someone may have drilled bypass holes or removed it completely.
Old Oct 13, 2015 | 09:28 AM
GrandSportC3
I will check for the thermostat.. However, even with the thermostat in place, the car should be running more than 160 degrees, especially here in the hot Florida weather..
Old Oct 13, 2015 | 09:34 AM
Kacyc3's Avatar
Kacyc3
If someone put in a 160* stat and larger than needed dewitts radiator it could be there, I see 171 in my ecm while cruising the interstate in 90* weather with a 406 and uncoated headers. If I drive the car before it hits the 160 it will stay there running down the interstate.
Old Oct 13, 2015 | 09:41 AM
GrandSportC3
On my car, no matter if I'm cruising at 60 mph, 80 mph or in stop and go traffic, the needle never even makes it to the 1/4 mark... it stops just short of it.. Only once in very heavy traffic on a 95 degree humid summer day, it went to be solid on the first line. The car seems to always run the same temperature, no matter if I drive her hard or if I just cruise around..
I have a fairly mild 350 in one of my previous '68 Verts with High Volume Water Pump, Griffin Aluminum radiator and a auxiliary 16 inch electric fan (in combination with a solid mechanical fan) and the car would somegimes get to over 200 degees despite all that.. It would run about 185 in most conditions but in stop and go traffic, it would get up to 200 degrees in very hot and slow traffic conditions despite overkill on the cooling system.
Old Oct 13, 2015 | 09:43 AM
Bloodzone's Avatar
Bloodzone
Just installed a dewitts 2 weeks ago. I drilled holes in my 180 stat to serve as a bypass because I'm running a vortec intake without a heater core connected. With stock 5 blade fan and Georgia temps in the 80s I run just above the 1/4 mark on the highway. In traffic I still hit 195ish, But it takes a good bit longer to get there. I agree 160 seems low for Fla in traffic.
Maybe its the gauge and not the sensor
Old Oct 13, 2015 | 09:46 AM
GrandSportC3
I will try to drive around for a while and then get a resistance reading on the gauge.. I know that 175 ohms is supposed to be 210 degrees and 109 ohms or so should be the 1/4 mark.. Let's see.. Considering that both sensors had the exact same reading, it's most likely the gauge that is inaccurate.. I doubt that it's the sensor considering the identical reading.
If the car wasn't mostly original and matching numbers, I'd just swap out the center gauges for autometer gauges.. Much more accurate reading..
Old Oct 13, 2015 | 09:54 AM
Bloodzone's Avatar
Bloodzone
I grabbed a thermometer temp gun off ebay for like 15 bucks. Works great and was cheap. Its really nice for diagnosing problems like yours.
Old Oct 13, 2015 | 09:59 AM
GrandSportC3
Were would you point the temperature gun? Is the block supposed to be the same temperature as the coolant?
Old Oct 13, 2015 | 10:11 AM
Bloodzone's Avatar
Bloodzone
If my gauge reads 195-200 my block will be about the same per temp gun. I was surprised how well they matched.
Old Oct 13, 2015 | 10:15 AM
GrandSportC3
Great.. Good to know that the temperature matches between block and coolant.. I used to have a temperature gun but my kids broke it.. Will get another one from Harbor Freight.. They are about $30 or so..
Old Oct 13, 2015 | 10:45 AM
cooper9811's Avatar
cooper9811
My observation - A higher-capacity radiator, as many aluminum ones are, can keep your overall temps down pretty low, often much lower than the stock setup (even with more power).
For example, with my 383 and a stock 4-core rad, I ran 185-190 actual temperature most days. On hot summer days with AC on, I could go just over 200 and then would hold there.
This last year I went to an SBC 427 setup with a high-capacity 3-core aluminum rad from Champion. I easily run 180-185 all day long, and may creep up to between 190 and 195 on a very hot day with AC.
I really didn't expect the new rad to be as efficient as it is, especially with a stroker of this size.
In both cases, I'm running a 180 degree thermostat and have kept the same temp sender unit between both engines (it is the factory sender matched with the gauge).
Old Oct 13, 2015 | 06:13 PM
GrandSportC3
This is what the gauge shows.. The sensor shows 56 ohms which appears to indicate that the gauge is fairly accurate. However, the infrared thermometer shows 185 degrees at the thermostat.. So, it appears that both sensors, the one that was in the car and the one I took out are inaccurate by exactly the same margin..
Old Oct 13, 2015 | 07:59 PM
65GGvert's Avatar
65GGvert
My 72 reads EXACTLY the same as yours and the IR gun shows 190 at the thermo housing.
Old Oct 13, 2015 | 08:53 PM
GrandSportC3
I finally solved the issue.. I actually had a different sensor that I purchased from a generic car parts site and never installed it as I wanted to be sure that it was the right one, so I ordered a different one from Paragon.. The one from Paragon showed the wrong reading, just like the one that was on the car. I ended up installing the generic one from carparts.com and it has the accurate reading.. I actually put both sensors in 100 degree water and measured the resistance.. I found a old thread where it says that the resistance of the sensor outside of the car should be about 220 ohms or so at that temperature.. The generic sensor had the correct reading while the one from the Corvette vendor had the wrong reading (just like the one that was on the car when I got it). Drove around for about 20 minutes and the gauge read just left of 210 degees which seems about right for 185 to 190 degrees... Problem solved.. Part number SITS6 at carparts.com
I believe the generic part number for it is TS-6 sensor.. Glad that I got the right reading now..
http://www.carparts.com/results/?Ntt...ype=global&N=0
Old Oct 13, 2015 | 10:57 PM
Bloodzone's Avatar
Bloodzone
Old Oct 15, 2015 | 07:27 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
My '71 gauge does the exact same thing. I just thought the gauge was going bad. Looks like I need a sensor as well! Thanks for the post!
To Low Coolant Temperature - is this normal??
Old Oct 15, 2015 | 07:45 AM
GrandSportC3
I was surprised that the El Cheapo sensor was the one that work while the more expensive one from the Corvette parts supplier didn't have the correct reading.. Weird..
Drove the Vette to work today.. 23 miles at 75 to 80 mph or so.. Temperature stayed just left of the 210 mark which seems to be about 190 degrees or so which seems to be correct..
Old Oct 15, 2015 | 07:27 PM
Kubs's Avatar
Kubs
Yeah I wonder if you just got a dud or if they are all off...
I found the same TS-6 sensor on RockAuto for $6. I'll report back when it arrives. Hopefully it fixes my issue too.
Old Oct 15, 2015 | 08:09 PM
forvicjr's Avatar
forvicjr
Hell, I was hopin ur car was actually runnin cool. I wanted to find the cause so I could appy it to my hot tempered 496.
