Edelbrock Air Gap Issues
Old Oct 16, 2015 | 11:01 AM
BEVO76's Avatar
BEVO76
Default Edelbrock Air Gap Issues
Happy Friday! Hope yall are well.
I am still having issues with my Edelbrock Air Gap in which the 4 center bolts are not sealing and I have oil pooling between sides of the intake and the heads. It is more prominent on the passenger side than the driver's side.
I have tried RTV Black, The Right Stuff, Permatex #2 as well as pipe sealant with NO luck. The only one that seems to slow it down is The Right Stuff.
You can even see where the oil is going down the side of the intake, down along the heads dripping onto the outside starter bolt, then down along the trans flywheel dust shield.
At this point I wonder if the intake is jacked up. Has anyone seen this same issue with the Edelbrock intakes???? I am about to pull the trigger on the AFR TITAN.
Thoughts?
Hope yall have a good weekend.
Bo
Old Oct 16, 2015 | 12:35 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
A couple of basics, before you start spending more money on different parts...
Are you tightening the manifold bolts in a criss-cross pattern, from the center out? What torque value are you applying to the bolts? IIRC, the spec is around 30-35 ft/lbs. have you checked the faces of the manifold with a straight edge, to ensure they're flat? What gaskets are you using? Are you using RTV or some sort of gasket to seal the "China walls"?
Old Oct 16, 2015 | 12:57 PM
BEVO76's Avatar
BEVO76
35lbs torqued, starting from the center and working outwards, manifold was machined so I know they are straight. Gaskets are FELPRO and I believe they are 1/8in thick...I cannot rememeber what part number they were. Black High Temp RTV to seal the china walls. No leaks at the china wall. Only on the sides where the centerbolts are located.
Old Oct 16, 2015 | 01:21 PM
BEVO76's Avatar
BEVO76
This might help diagnose a little better. I do not see oil coming from the bolt holes. On the Air Gap the centerbolts are on the inside of the manifold, there is no oil leaking from there. But when the car is running if you look at where the intake, gasket and heads all meet you can see small air bubbles where the oil is pooling. Does that make sense?
Old Oct 16, 2015 | 01:25 PM
toobroketoretire's Avatar
toobroketoretire
I would like to see pictures of both sides of your engine..................
BEVO76's Avatar
BEVO76
I am really considering going with the AFR TITAN. That composite base and intake have a little more flex than a cast intake. I might be able to get that to conform better to the heads. Plus it dosent use intake gaskets from what I am tracking.
I dont want to open a can of worms but the heads are a pro comp.
Old Oct 16, 2015 | 01:31 PM
jim2527's Avatar
jim2527
Was it machined down so much that its now mis-matched?
Old Oct 16, 2015 | 01:46 PM
BEVO76's Avatar
BEVO76
I do not think so. It was machined because the china wall would not seal. The RTV bead after torqued was paper thin and would not seal correctly. It was then machined to get me a 1/8in gap as well as using the 1/8in intake gaskets to get me a little more height.
Old Oct 16, 2015 | 01:52 PM
BEVO76's Avatar
BEVO76
BEVO76's Avatar
BEVO76
Old Oct 16, 2015 | 01:54 PM
BEVO76's Avatar
BEVO76
This is the best I can do right now for pictures. But you can def see how the Air Gap intake fits to the heads.
Old Oct 16, 2015 | 05:11 PM
leadfoot4's Avatar
leadfoot4
No, it doesn't make sense, but let me ask this.....Do you have a functioning PCV? It almost sounds like you have an internal pressure problem.
Old Oct 16, 2015 | 05:46 PM
BEVO76's Avatar
BEVO76
PCV was functioning and replaced with a new one that also works just to be sure.
Old Oct 16, 2015 | 05:47 PM
toobroketoretire
I am suspecting you created your problem by machining the front and rear then using super-thick 1/8" gaskets on the sides. Check the sides with a good straight edge and I'll bet you'll find you have twisted it out-of-shape by torquing it to 35 ft/lbs when an aluminum manifold only needs about 15 ft/lbs. If the 1/8" gaskets are softer than the standard FelPro gaskets it crushed on the ends and left the center high. Check it.....................
Old Oct 16, 2015 | 09:44 PM
BEVO76's Avatar
BEVO76
We had it off twice and double checked everything to include tolerances. I am positive this intake is not warped. This is got to be something easy that I am simply overlooking.
I still bet that AFR TITAN would solve my issue. Plus its a good way to pick up a few extra HP.
Old Oct 16, 2015 | 10:02 PM
7t9l82's Avatar
7t9l82
Your pcv valve may not flow enough. See if you can find a way to vent it more.
Old Oct 17, 2015 | 06:00 AM
terrys6t8roadster's Avatar
terrys6t8roadster
The Titan is an impressive manifold, but an expensive experiment to stop an oil leak.
They make washers that have rubber seals on the inside to seal bolts from leaking. New Holland used them for their chain cases and the lower bolts were below the oil level. They need them replaced every time they are dissembled. I use them on my valve cover studs that always leaked. T
To Edelbrock Air Gap Issues
Old Oct 17, 2015 | 08:23 AM
leadfoot4's Avatar
leadfoot4
The FACTORY torque spec for a '92-'97 LT-1 aluminum intake, being torqued to an aluminum cylinder head, is 35 ft/lbs.............
Old Oct 17, 2015 | 09:05 AM
diehrd's Avatar
diehrd
Your sure it is not the valve cover ?
Gasket damage ?
If the manifold is true then the head is not ?
Also say what you will about the PCV , but if you can push oil and are getting air bubbles your sure putting a lot of blow by into that crank case .
Old Oct 17, 2015 | 10:22 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My bet is the machining of the intake put it out of whack with the heads.
It is not easy to machine a intake to fit the heads properly, did they have the engine when they did the machining ? Were the heads ever machined ?
