Transmission help needed
Old Aug 25, 2002 | 05:44 PM
vetteflame79's Avatar
vetteflame79
St. Jude Donor '06
Default Transmission help needed
1979 Automatic transmission. After car is warm, car seems to hesitate before engaging in gear. It seems to shift fine from second to third. The fluid level is full. Any suggestions or help?
Old Aug 25, 2002 | 08:38 PM
Larry B.'s Avatar
Larry B.
Default Re: Transmission help needed (vetteflame79)
The first thing to do is change the filter and fluid. Use G/M fluid (A/C delco) or Valvoline. Do NOT use rags to wipe the pan. Rags cause lint which is not good for the transmission valves. :nono:
Old Aug 25, 2002 | 09:24 PM
drspeedy's Avatar
drspeedy
Default Re: Transmission help needed (silvervetteman)
Old Aug 26, 2002 | 07:56 AM
vetteflame79
St. Jude Donor '06
thank you
Old Aug 26, 2002 | 08:32 AM
BB wowbagger's Avatar
BB wowbagger
I have absolutley no idea,but i added a choice in the poll,not that it will help you,but it sounds kinda fun.I wonder how long a trnny will work before its life ends?Any ideas? :cheers:
Old Aug 26, 2002 | 08:44 AM
BB wowbagger
This is a good start..
Old Aug 26, 2002 | 11:37 AM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
My '76 did the same thing, but it only do it when it was cold. There was some kind of obstruction in a "valve" somewhere. My mechanic said it was an easy fix. I don't think it was internal, but changing the filter and fluid are a good idea anyway.
BTW There is a LOT of fluid in a transmission. When I did mine, the oil change tub that I used to catch the fluid overflowed and flooded my driveway!
To Transmission help needed
