3D print, intake
Old Oct 29, 2015 | 12:25 PM
c3_dk's Avatar
c3_dk
Originally Posted by spacemanspiff
I've made a couple things for our 72 Vette. While re-doing the interior I wanted to mount a pair of 4x6 speakers in the kickplate but didn't want to "bubba" it like the previous owner who just screwed them through the plastic trim plate. I 3D printed a couple of mounts which fit to the openings in the birdcage perfectly and utilize factory mounting holes.
I printed a few misc. broken plastic clips and reinforcements for cracked trim pieces.
I also printed a carb stand for rebuilding the Holley carb, worked pretty awesome actually!
GREAT, it looks very good :- )
Lets see more of this !!
Old Oct 29, 2015 | 04:31 PM
spacemanspiff's Avatar
spacemanspiff
Cruising
I've had a bit of experience over the years with both home built 3D printers (like the one used to print the parts I showed above) to commercial laser sintered metal printers. The tech is cool and the barriers for entry are coming down while the quality is coming up. That being said, I have been less than impressed with the quality of parts produced using the laser sintered stainless steel process.
The parts tend to be grainy (rough) in nature and have a tendency to warp due to uneven cooling of the part. On the plus side, it can be machined and tapped like normal stainless. They also tend to be porous and in the case of an intake would take a hell of a lot of post production work (polishing ports, machining mating surfaces flat) that it probably wouldn't be worth the effort for the average home mechanic. As a little experiment, I found a CAD model of a typical Edelbrock intake and uploaded it to Shapeways (an internet printing house) and while they could do it, it would cost roughly $17,000. Parts are priced per cm3, so 3400 cm3 of material @ $5/cm3 = .
Your best bet, given the cost of the technology today, would be to print the part from an affordable plastic material to produce a "lost wax" type of mold and cast it in aluminum. We've done this for smaller hardware parts with decent success rates.
Don't get me wrong, there will come a time in the not too distant future when you go online, type in the specs on the part you want and they "print" you a one off that is suited exactly to your needs. Producing production casting molds are extremely expensive and at some point it will make financial sense to abandon traditional casting methods in favor of a printed (or at least partially printed) part.
If you are at all interested in what the bleeding edge of the 3D printing world is, definitely check out http://www.3ders.org/
Old Oct 29, 2015 | 04:39 PM
Priya's Avatar
Priya
I'm surprised to see so many 3D printers under $1000 U.S. My husband looked at one in a hobby shop recently, I wasn't paying a lot of attention, but I thought it was $2-$3000. Of course Canadian prices are 30% higher, but still.
Old Oct 29, 2015 | 04:56 PM
The13Bats's Avatar
The13Bats
The story was on my latest copy of Popular science I have yet to have time to check it out,
http://www.popsci.com/videos/video-c...-d-printed-car
Old Oct 30, 2015 | 03:00 AM
Ronaldo's Avatar
Ronaldo
NICE
Old Oct 30, 2015 | 08:43 AM
dembo's Avatar
dembo
Nice work Spaceman
Sport mirror (generic) spacer to make the mirror sit horizontal instead of tilted inwards (look I don't like and there's more visibility towards the rear when they are horizontal)
repro vs printed
test fit
Painted
Old Oct 30, 2015 | 10:10 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Very nice. I think others on the forum would like this. Nicely done.
David Howard
Old Oct 30, 2015 | 10:59 AM
redvetracr's Avatar
redvetracr
I tried getting some of these made using 3d printer technology, it`s the plastic button inside a 70ish & up tach drive distributor, the printing is not the expensive part it`s the writing of code or software or whatever that tells the printer what to do thats the expensive part, I am still looking if anyone knows someone...
Old Oct 30, 2015 | 11:34 AM
dembo's Avatar
dembo
I do 3D modelling as a living (freelancer). If anyone needs a 3D model and export file to send to printer (.STL) for example, just shoot me a message. If I have time and you have a sketch I'll model it. for free ofcourse
Nick
Old Oct 30, 2015 | 02:10 PM
David Mc's Avatar
David Mc
The vent retainers in the rear A/C unit of my '72 Suburban were cracked.
I drew them up in Sketchup (free) and exported it to the correct file (STL- free add on) and voila
Old Oct 30, 2015 | 02:14 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Wow! I want one!!!!
Jebby
Old Oct 30, 2015 | 03:39 PM
spacemanspiff
Cruising
For those that would like to make one of the carb stands yourself, you can download the STL file (the standard file type used by most 3D printers) free of charge from here.
http://www.thingiverse.com/thing:387375/#files
I looked into what it would cost to print from Shapeways but it looks to be prohibitibly expensive (+$250). If you have access to a 3D printer at home or through a friend, have at it!
Old Oct 31, 2015 | 08:44 AM
  #33
gbarmore's Avatar
gbarmore
I created a prototype of this using PVC pipe and some other materials, then had one of our CAD Engineers draw it up in Autodesk Inventor, export to an .stl file and we printed it on a 3D Systems machine. Painted it black and wallah! I don't miss the ashtray one bit.
I've considered having a few more of these printed and offering them to forum members at my cost. If there is interest I will get the pricing together from our print group so you can see if it is justifiable.
Old Nov 1, 2015 | 05:07 AM
  #34
c3_dk's Avatar
c3_dk
Looking very nice, amazing what we will be able to do in the near future, with printes that all can afford to buy.
I'm still looking forward see the first intake, maybe just as a drawing, ready for printing?
Old Nov 1, 2015 | 01:50 PM
  #35
alconk's Avatar
alconk
Very nice but what I noticed was the gear shift pattern. I have an 82 and modified the detent to shift into 1st but would like the plate showing. Could you share what you did please.
Old Jul 16, 2016 | 04:56 AM
  #36
c3_dk's Avatar
c3_dk
Originally Posted by c3_dk
When will we see the first 3D printed intake?
Please show the 3D printed parts you have made for your Corvette
Time goes, new printers are getting better and better.
Anyone printet something?
I'm looking forward seeing the first intake.
Old Jul 16, 2016 | 07:52 AM
  #37
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I wouldn't hold my breath. Non-metal engine parts have been toyed with for decades but there aren't any engines being manufactured to date that I'm aware of regardless of the manufacturing process. The AFR Titan intake works but I doubt it was made in a 3-D printer and its expensive. Heat is the enemy for non-metallic parts. As noted earlier, sintered metal 3-D printers are now being developed. I saw a state-of-the-art version of one with 3 lasers. A 5 gallon pail of powdered metal was about $20,000. However, to say the results were phenomenal is an understatement!
To 3D print, intake
Old Jul 16, 2016 | 10:07 AM
  #38
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Any chance this could be made without the Corvette Logo?
I am building a custom 72 Road Race Replica and I think this would be stunning on the car for two additional gauges. I will put three toggles where the corvette logo is located, hence my request.
Or could "Road Shark" be added where the work "Corvette" is located?
Interested, quite interested.
David Howard
AllC34Me
Old Jul 16, 2016 | 01:31 PM
  #39
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Just think about a 3D printrd intake manifold, you could make the runners perfect, any port size in any position that would be cool
Old Jul 16, 2016 | 01:46 PM
  #40
c3_dk's Avatar
c3_dk
YES, make the intake that fits 110% that is what I mean, buy the heads in the morning, print a intake in the afternoon.
I know it's a longshot, but my god it would be nice.......
