O2 Sensor Readings
Old Oct 25, 2015 | 05:25 PM
toobroketoretire's Avatar
toobroketoretire
Default O2 Sensor Readings
Several years ago I installed an O2 sensor into my gutted heat riser block so I could check my air/fuel ratio at various loads and speeds. I found its showing .700 volts at light-throttle cruising speeds running #70 jets and .900 volts running #72 jets (454" with a #3310 Holley).
How many of you have installed an O2 sensor as a diagnostic tool?
Old Oct 25, 2015 | 06:22 PM
Shark Racer's Avatar
Shark Racer
Sounds like you're running a narrowband - there are plenty of people on here who use WBO2 to tune - this lets you get spot on when you're setting your target outside of stoich. I used WB to tune the ECM on my truck and the Q-Jet on my 78, as well as the Q-Jet on a friend's 70 496 'vette.
700mV is pretty good for cruise, though.
Old Oct 25, 2015 | 07:00 PM
toobroketoretire
I was just curious how many of you have installed an O2 sensor for diagnostic purposes.
Old Oct 25, 2015 | 07:24 PM
Haggisbash's Avatar
Haggisbash
I have but only for tuning, its not left in place afterwards.
Old Oct 25, 2015 | 07:36 PM
johnt365's Avatar
johnt365
I swapped out the clock for a wideband O2. I find it very helpful for tuning.
Bung is in the drivers header.
Old Oct 25, 2015 | 08:56 PM
Richard454's Avatar
Richard454
I'm running a wideband as well-w/ a Megasquirt MS3Pro
Have a USB port for the laptop but can also do bluetooth to my phone w/ an adapter...Plus the Innovate piece I'm running has an output for a gauge.
Like what johnt365 has done-but wanting the hide the AFR gauge. Looking at one of these small ones like this -
data logging-
[img]data logging by Richard Hayes, on Flickr[/img]
ECU
P1010670.jpg~original by Richard Hayes, on Flickr
Tuner Studio Software-
DSCN5168 by Richard Hayes, on Flickr
What's being tuned-
Old Oct 26, 2015 | 05:59 AM
Blue Juice's Avatar
Blue Juice
Reading thread's you tell that plenty of people use them.
I have one as a semi-permanent install beside a vacuum gauge and a mechanical oil pressure gauge. I can remove them or swap them for fuel pressure, voltmeter, ammeter, etc as necessary.
These 3 have been in place for over a year though.
Found that what I thought was over rich-idle, was actually over-lean, and corrected a slightly lean cruise condition that I wasn't aware of. So glad I bought it.
Old Oct 26, 2015 | 08:38 AM
Danish Shark's Avatar
Danish Shark
AEM analog gauge in place of the clock:
Old Oct 26, 2015 | 12:49 PM
lionelhutz's Avatar
lionelhutz
Wideband sure. It's a really good for tuning.
The narrowband you're using is useless for anything except telling you if you're rich = greater than 0.45V or lean = less than 0.45V
To O2 Sensor Readings
