overheating problem
Old Oct 28, 2015 | 11:11 AM
JMurry1's Avatar
JMurry1
7th Gear
Default overheating problem
I have 76 corvette put In a 350 runs great except overheats if drove a few miles. I have flushed the radiator, checked the water pump, it has a clutch fan but I added a electric fan and over flow. Anyone have any ideas? Please help
Old Oct 28, 2015 | 11:31 AM
rcread's Avatar
rcread
I can predict one reply from a certain member!
Do you have the seals around the radiator and between the hood and radiator support?
Old Oct 28, 2015 | 12:30 PM
JMurry1's Avatar
JMurry1
7th Gear
Yes I have put new seals on everything when I transferred engines
Old Oct 28, 2015 | 01:50 PM
REELAV8R's Avatar
REELAV8R
More details would help.
When does it over heat, at cruise or idling or both?
What thermostat are you running?
What radiator are you running?
How are you classifying overheating, getting above a certain temp or are we talking boiling over?
What has been done to the engine?
Where is your timing set?
Does it have the front air dam installed?
What electric fan are you using, dual or single and does it have a shroud?
Old Oct 28, 2015 | 04:27 PM
JMurry1's Avatar
JMurry1
7th Gear
It will overheat idle or driving quicker while driving. It does have a fan shroud. It has a single 12in electric fan as well as the clutch fan. The radiator is stock. Not sure the timing and we just straight switched out the engine from the blazer and a mechanic did all that stuff. Also it will overheat to the point of boiling over. Never had any overheating problems while in the engine was in the blazer
Old Oct 28, 2015 | 05:41 PM
toobroketoretire's Avatar
toobroketoretire
I suggest you take a pressure check and see if hydrocarbons are entering your cooling system from a leaking head gasket. Does the fan clutch drive the fan HARD or just barely. When fast idling it should blow a LOT of air and if it doesn't the fan clutch is likely failing. And the little 12" fan doesn't do diddly squat to help anything.
Old Oct 28, 2015 | 06:42 PM
rcread's Avatar
rcread
Called it!
Old Oct 29, 2015 | 10:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "over heating." What temperatures are you seeing?
Old Oct 29, 2015 | 10:08 AM
JMurry1's Avatar
JMurry1
7th Gear
Boiling point. Well over 200 degrees
Old Oct 29, 2015 | 11:27 AM
COOLTED's Avatar
COOLTED
Is your lower radiator hose the non-collapsing kind?
Old Oct 29, 2015 | 12:58 PM
mikep3's Avatar
mikep3
Water and antifreeze with a 15 psi cap boils at about 260F.
Are you using a IR gun to check the temperatures.
If the new engine has Vortec, heads you have a temperature sending unit that is not calibrated to the gage in your car?
Your new motor might have a 195F thermostat.
Old Oct 29, 2015 | 04:19 PM
7T1vette's Avatar
7T1vette
How old is the thermostat and what condition is it in? (This should get changed out whenever the coolant is changed.) Thermostats go bad. Some fail 'open'; some fail 'closed'.
Old Oct 29, 2015 | 04:35 PM
cobrachuck's Avatar
cobrachuck
As you can tell a bunch of us have been down this road.
Can you feel the stock fan pulling air through the radiator? Check your air flow.
Clutch fans can & do go bad, a stock 7 blade AC clutch fan movers a ton of air across the radiator.
Old Oct 29, 2015 | 09:49 PM
Patro46's Avatar
Patro46
Hmmm. I've heard if you install a DeWitt's radiator, no matter what the problem is, it will cure the overheating issues, airflow or fan issues be d*mned. I can't personally confirm this, but that's what the buzz around here says
Old Oct 30, 2015 | 06:48 AM
diehrd's Avatar
diehrd
which SBC is in it ? You mention a blazer what year ?
Old Nov 2, 2015 | 11:40 PM
Bills17n72's Avatar
Bills17n72
is the spoiler that is supose to be underneath on the car?
Old Nov 3, 2015 | 12:43 PM
Kacyc3's Avatar
Kacyc3
based on you saying it overheats at idle and while driving, in order for this to happen at both of these situations, you have to have a closed thermostat, collapsing lower hose, clogged radiator (inside or outside) or the timing is wrong. If the clutch fan were bad it would cool while driving, and adding the efan would help at idle neither of these happen.
Check these problems before you buy parts it will save you money and hassle in the long run.
I have a 406 in my car with uncoated headers and it would still cool down while driving WITHOUT the seals around the radiator and hood.
To overheating problem
Old Nov 3, 2015 | 08:11 PM
JMurry1's Avatar
JMurry1
7th Gear
The efan is 18inch and it is mounted on the outside of radiator. Should the fan be blowing on the engine or pulling the hot air towards to front of the car
Old Nov 3, 2015 | 08:18 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Best answer
Old Nov 3, 2015 | 08:30 PM
The13Bats's Avatar
The13Bats
no you didn't...
Oddly the last thread about overheating the cat fixed it with a Champion radiator and new name brand fans...so that might be a sign one of the seven seals has broken....
yeah, one 12" wasn't gonna hack it in this threads case, I would want to be sure the gauge is correct and go from there....
