Exploding C3 Myths
"It is ignorant people who start these silly myths and ignorant people who perpetuate them".
Toobroketoretire 2015
1. The higher the flow rate the more dirt passes thru
2. The lower the flow rate the less dirt passes thru
Since the whole object of an air filter is to stop dirt from entering your engine its only obvious you want the most restrictive air filter possible but with the largest possible size. As the engine compartment of today is filled with all kinds of whim-whams and gizmos its impossible to put a huge round air filter in so the manufacturers had to resort to making them in smaller packages but with the same square inch area; usually around 40-45 square inches (a 14" X 3" has 42 square inches). So its easy to design a 6" X 7" filter that has 42 square inches of area. The Tri-Power GTO's in the mid 60's had three 2" X 7" air filters with a total of...............42 square inches of area! And as long as those 3 little filters were ran in relatively dust-free conditions they lasted for years before needing replacing.
When I see new Corvettes rolling off the assembly line with oiled cloth air filters on them only THEN will I be convinced they are better. But until that day comes I'll continue to use my 14" X 3" "restrictive" air filter and replace it every 5 years at a whopping cost of $7.50.
Read the last sentence in the procedure. Doing figure 8's is recommended by GM.
Not that you'll pay any attention, but possibly someone else will read it to know that you are wrong.
Besides, do you have access to all the service procedures for a C3 online?
Just sayin'
LOL, you beat me to it. The last time I checked the area of the outer surface of a cylinder is 2 x pi x radius x height and not height x diameter.
14" x 3" cylindrical filter = 132 square inches ignoring the pleating.
3 of 7" x 2" cylindrical filters = 132 square inches ignoring the pleating.
As noted, he also ignored the pleating when talking about the actual surface area of the filter material.
1. Chevrolet hydraulic lifters need to be adjusted "hot and running". That's not true. Chevrolet hydraulic lifters have approximately .150" of plunger travel and it takes 1-1/8 turns of the rocker arm's adjustment nut to center the plunger. The shop manual calls for 1 full turn down from ZERO lash to make the adjustment easy but anything from 3/4 to 1-1/2 turns is fine which makes adjusting them "hot and running" a silly and messy waste of time. Never turn the adjustment nut down only 1/2 turn because that really screws up the geometry of the valve train.
3. Thermostats need holes drilled into them. That's not true. The only advantage holes give you is the ability to fill the cooling system a tiny bit faster. But in real cold weather those holes will prevent the engine from warming up quickly because coolant is being allowed to circulate thru the radiator prematurely.
11. Chevrolet engines need 36 degrees of total timing in by 2000 rpm. This is true for drag racing when running 100+ octane gasoline but for street engines running 87 to 93 octane gasoline 30-32 degrees @ 4000 rpm is preferred to prevent pinging. If 36 degrees @ 2000 rpm was needed for street driven cars G.M. would have provided distributors that allowed that.
15. The steel push rod guide plates are for "assembly" purposes. That's not true. The steel guide plates are necessary for all of the 2.02" X 1.60" valve heads because they have a 1-7/8" center-to-center valve spacing; 1/8" wider than the smaller valve heads that use a 1-3/4" center-to-center valve spacing. As cast iron is relatively soft slots in the head would quickly wear out from the side thrust of the crooked push rods.
-- Joe
I normally warm up my car stationary at least until the water gauge moves off the peg. I prefer it to warm to 160, but that doesn't always happen.
My oil pressure, however, remains at 40 to 40 psi for quite a while. I drive easy out of the neighborhood and to the first traffic light perhaps 3 miles away. Even then the oil pressure is still high, a clear indication that it has not warmed sufficiently.
It isn't until the NEXT traffic light another 4 mile drive (at 2,500 RPM) away that when the oil pressure gets to ~20 psi at idle. I know then that the oil has warmed to 'operating temperature' and I can start to have fun with the car.
Interestingly enough, my engine builder encouraged me NOT to get an oil temperature gauge when I got a full set of AutoMeter gauges. After living with the cluster I ultimately purchased, I totally agree with him. I can tell all I need to know about the oil temperature by reading the oil pressure, especially at idle.
A little off the subject:
I will further say that connecting the oil pressure gauge with a full-sized #4 hydraulic line made a MASSIVE difference in the utility of my oil pressure gauge. When you pass it through the pitifully small stock (or 'upgraded' copper) lines, it takes many seconds for the gauge to react to the actual oil pressure in the engine.
With the #4 line, my mechanical oil pressure gauge reacts as quickly as does my tachometer. It's very entertaining to watch them bounce around. And it is VERY, VERY informative to have an immediate and accurate oil pressure reading. That is BY FAR the most informative gauge in my cluster.
In the case of oiled cloth air filters the manufacturers started the myth of "more restrictive" in order to provide the cure at 4 to 5 times the cost PLUS the cost of the expensive oil for those filters. Slick, huh?
