Exploding C3 Myths
You think 1.125" turns is required???? 1/2 turn works fine and is even recommended by aftermarket manufacturers like Comp Cams.
As for hot and running. Maybe not required but it works and some pro engine builders do use it. Once you have cutout valve covers it's likely just as quick too without making a mess.
It's been recommended in service bulletins put out by the various manufacturers as part of the cure for a chattering differential. It's certainly not required, but it quickly gets the oil with the proper amount of additive into the clutch pack so the problem is gone when the vehicle is given back to the customer.
Yes, a mechanical secondary carburetor can be used on a street engine but a vacuum secondary or AVS carburetor offers much better low rpm performance because of the limited throttle opening and that is why the factories have always used them. For stock L-48's I highly recommend using a #1848 465 cfm electric choke Holley because of it's smaller primary venturi sizes or the OEM QuadraJet for the same reason.
Second, who goes WOT at low rpm's? Have you ever heard of rolling the throttle as in gradually opening the carburetor. The throttle is not a digit device (closed/WOT) and wasn't ever meant to be used like that. So I guess if you have NO driving skill, then vacuum secondaries are the ONLY way to go.
Third, if a mechanical secondary carb is having troubles below 4000rpm, it needs tuning and I don't mean changing jets! There are many other aspects of tuning a carburetor (power valve orifice size, accel. pump size and rate, accel nozzle size, etc.).
Well, works great. Adjustable ride height. Adjustable compression and rebound. Works like its supposed.to work.
You DID notice on Speed Directs own website it does not say it will improve your car's handling nor about fixing the #1 largest deficiency of the C3's rear suspension ... the inherent toe change (rear steer) with wheel movement. Just reading what their add actually says, and not what is implied.
but that said, the "slow enough to do it's job" is pure bunk and has been proven more times than is worth even discussing...
btw, here's one: If you want your AC to get colder, put a smaller pulley on the compressor to slow the flow down, then it will get colder in the evaporator...
Most (all?) modern vehicles are equipped with knock sensors that exist, in general, to retard engine timing in response to detonation. In a nutshell, one single ping results in timing being pulled back to whatever point is necessary to NOT having the engine ping. The computer does this automatically.
What happens when you put premium gas in the same car? The engine is less prone to detonation...less ping...given a particular timing setting.
The computer will then allow the timing to advance (to a certain point) to the new "ping point" based on the higher octane gasoline.
Obviously, this is a simplistic explanation.
I've run both fuels in my Volvo XC90 with the 4.4L V8 and the difference is nearly imperceptible.
I've run both fuels in my "beater" Subaru Outback with the 3.0L H6 engine and the difference is fairly profound. It doesn't turn the car into a "tire smoker" (it is AWD), but there is enough of a difference in power that it is easily felt.
I don't believe I've ever called anyone "ignorant" because they believe one thing or another. I smile and don't choose to buy what they're selling.
99.765% of the issue with this thread is the inflexible tone and words being used to make a point. The other 0.235% of the issue with this thread is the lack of evidence to support the statements.
It's a painful read.
I don't know why I participate other than, like others, I hate for the misinformation to get perpetuated without correction.
Second, who goes WOT at low rpm? .
pseu·do·sci·ence
ˌso͞odōˈsīəns/
noun
noun: pseudoscience; plural noun: pseudosciences; noun: pseudo-science; plural noun: pseudo-sciences
a collection of beliefs or practices mistakenly regarded as being based on scientific method.
It contains enough detail to fool the unwary or inexperienced layman.
It does not contain the necessary details to actually be fact. Because he himself does not understand the mechanisms behind his statements.
Therefor his lack of knowledge and belief on a subject is passed on as their own "myths", but the inexperienced see it as fact.
To those who would believe everything or anything toobroke says I would say to you, be wary, be smart, and do your homework.
Do not take glib statements at their face value.
pseu·do·sci·ence
ˌso͞odōˈsīəns/
noun
