sensor expertise for 1982 needed
Old Nov 18, 2015 | 02:17 AM
slickfx3's Avatar
slickfx3
Default sensor expertise for 1982 needed
sorry don't know what is what and don't have a "factory manual" corvforum is my manual..
what is what on my 82
think the switch between plugs 6 and 8 is my aux fan switch
how about the one above the starter?
etc.etc.
Old Nov 18, 2015 | 03:06 AM
toobroketoretire's Avatar
toobroketoretire
Yep, the two-terminal switch that is screwed into the head above/between #6 and #8 is for the electric fan and the switch that is above/between #1 and #3 is the temperature sender for the gauge. The switch above the oil filter is for the engine oil temperature and the switch at the front/right of the intake manifold is for the temperature sensor for the ECM. The BIG switch next to the distributor is for the oil pressure and it also turns on the fuel pump relay.
Old Nov 18, 2015 | 11:20 AM
slickfx3's Avatar
slickfx3
no knock sensor?
i don't have an oil temp gauge
Old Nov 18, 2015 | 12:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by slickfx3
...don't have a "factory manual"...
Why not break down and order one?
Old Nov 18, 2015 | 12:50 PM
slickfx3's Avatar
slickfx3
you got me, I stopped buying books when I had to stop studying for stuff for examinations
maybe, I have no excuse, maybe the costs? lame reason...
Old Nov 18, 2015 | 01:46 PM
Vince'82's Avatar
Vince'82
Knock sensor is in front of the starter bolted to RH block drain hole
Old Nov 18, 2015 | 10:14 PM
TimAT's Avatar
TimAT
Compared to the expenses of buying parts that are not need for the problem, and the time spent chasing ghosts, the FSM is cheap. Not to mention how much easier it is to simply FIND which switch/sensor is at that particular spot.
Old Nov 18, 2015 | 11:50 PM
lionelhutz's Avatar
lionelhutz
No, it doesn't. There is a pressure switch that connects from +12V to the fuel pump. But, the ECM ALWAYS energizes the fuel pump relay when the engine is turning over (cranking or running). So, the only conceivable purpose for the pressure switch is a backup to the relay.
Pretty much every early GM fuel injection systems had that pressure switch and you could disconnect or remove it without affecting the operation.
Old Nov 19, 2015 | 12:01 AM
lionelhutz's Avatar
lionelhutz
Here are some of the injection parts,
TPS
IAC motor
VSS
ESC module
canister purge solenoid
EGR solenoid
MAP sensor
Old Nov 20, 2015 | 03:48 PM
hugie82's Avatar
hugie82
I agree and dis agree.
If you're not showing oil pressure the fuel pump is shut down. The ECM goes thru a priming cycle when the key is turned on. That's enough to start the engine and show oil pressure. Without that circuit being complete the ECM will kill the fuel pump relay. I guess a jumper could solve this but it's just as easy to install the correct oil pressure sending unit.
Old Nov 20, 2015 | 06:09 PM
lionelhutz's Avatar
lionelhutz
You can find lots of people claim it works that way, but they don't know what they're talking about. They see the OPS in the wiring and just ASSUMe it works that way (why else would the switch be there, right?). You can unplug the OPS as long as the fuel pump relay is working. Same applies to all the other GM injection systems through the early to mid 90's that have the OPS. Eventually, GM began to drop the OPS and rely on the relay only.
Old Aug 7, 2017 | 06:06 PM
6mn Vette's Avatar
6mn Vette
Interesting. My GM Shop Manual for my '82 specifically lists a pressure switch that disallows ignition until it reads a minimum pressure (4PSI, If I remember correctly) thus all the extra cranking when the car has sat for awhile before starting. I always assumed it was meant to prime the motor (lubricating cam, lifters, etc.) with oil prior to ignition.
To sensor expertise for 1982 needed
