Getting my trailing arms rebuilt and the service offers new rear brake rotors for a additional charge of 40.00 each. I think my existing rotors look good, but wondering what is the correct rotor thickness is suppose to be? I would like to measure with a caliper but don't know what number I should be looking for. What would thickness be on a new pair and is the maximum wear amount?
I am not going to dig through my manual because the numbers should be online, but i just looked at some rotors in my stack and the pad doesn't run out to the outer edge. so if they don't have a worn ridge they are probably good unless they are warped.
The other thing is setting the run out to less than .002
The MINIMUM thickness you can turn it down to is 1.230" ( and this does NOT mean that you can take a lot more material off of one side than the other. They STILL have to be basically the same thickness for heat.)
If it is BELOW 1.215"...they are DISCARDED.
When I do the trailing arms, spindle bearings and brake rotors....I make sure the rotor is WELL in the guidelines. Just taking a new rotor and putting it on a spindle DOES NOT GUARANTEE that it will always work out when it is measured. And that is ASSUMING that the spindle has been indexed and checked to make sure that it is correct sot eh mounting flange where the rotor comes in contact with is true. Because if ti is off enough...it may require shim stock to be installed to get the rotor true....so this does not effect your brake calipers. AND...it does not matter if the calipers have the 'O' ring design seals...because I have seen them leak also. BUT ...making sure your rotor is correct is IMPORTANT if you have the lipped seals in your calipers.
Correct new thickness is 1.250 but in the real world it's usually 1.255
Minimum thickness is 1.215 .
Mike
I recently replaced all four rotors with drilled/slotted cryo-treated ones. However......the original 47 year old ones were in perfect condition. No scratches or scoring and no ridge on the outside edge. Very high quality steel used back then, so if yours are not warped you can save $40 each.
One of the few tech videos that I COMPLETELY agree with. Such an important step that is overlooked by so many.
DUB
It is much more fun my way! I use beer cans. After draining the can I use a razor knife to make pie shaped wedges that fit between the studs. I've also used aluminum foil. On a surfaced rotor it is possible to get down to effectively "ZERO" run out
...back in the day...I used whatever it took to get it right...because this was before the internet and the ease of finding a company that would sell the correct tapered shims.
Bottom line... getting it as close to ZERO as possible.
