No reverse
Old Nov 19, 2015 | 10:45 PM
WHITE 1974's Avatar
WHITE 1974
Default No reverse
Hi guys, on the way home tonight go to park in my spot underground and crap no reverse gear ( TH400) all forward gears are good however when it's between park and reverse it's still in a forward gear....I'm thinking shifter cable it was perfect before this it's driven every day April to November about 6000 miles or more a year about 28000 miles on a completely rebuilt trany with shift kit and like I said until now 0 problems. If it matters at all its a small block.Thanks for any input.
Old Nov 19, 2015 | 11:04 PM
toobroketoretire's Avatar
toobroketoretire
If you can feel the individual detents (R, N, D, 2, 1) its not the shifter cable. The early TH700R4's had a carburetor type clip that connected the shift spool link to the detent plate and perhaps your TH400 has one of those clips too. I suggest dropping the oil pan and look the internal linkage over and also look in the bottom of the pan for signs of a tiny broken clip.
Old Nov 19, 2015 | 11:21 PM
Brass Pass's Avatar
Brass Pass
It could be that a Reverse Servo Accumulator seal has gone bad. When I had a TH400 in my car that was the problem when my reverse went out. All forward gears worked fine.
It is located on the valve body and has a round cover. You will have to drop the pan.
Old Nov 19, 2015 | 11:26 PM
WHITE 1974's Avatar
WHITE 1974
I can feel all the detents. I looked quickly at some diagrams there appear to be some external clips also I just can't get under to look tonight pushed it back into my spot so I can still drive to work in the morning....I'm actually a service advisor by trade and I'll be able to get it into the shop just trying to get a head start on any parts I'm going to have to track down I am really hoping it's external though thanks for the advice. I see your in Texas believe it or not it was actually 67 degrees here in Toronto today! CHEERS ERIC
Old Nov 20, 2015 | 05:19 AM
7T1vette's Avatar
7T1vette
The shift cable can be worn/damaged so that either REVERSE or LOW will not engage, but the other ranges will still feel like they have detent. Look at the shift cable where it attaches to the shift arm (on the left side of the transmission). Watch it as someone else shifts through ALL the ranges (with engine NOT running, of course) and look for any kinking of the cable between ranges and/or when reversing cable direction.
My bet is on a worn-out shift cable. Nothing lasts forever.....
Old Nov 20, 2015 | 05:06 PM
WHITE 1974's Avatar
WHITE 1974
Default fixed
Thanks guys I got it up on the hoist everything looked fine externally was prepared for the worst when my buddy says " cable may be a bit loose won't hurt to snug it up it seems a little longer than I remember" Now I have reverse again I remembered stalling at a light in the way home as the air temp had dropped about 30 degrees and quickly slamming back to park to restart I guess in my panic at the lighat I was to rough at any rate thanks again for all the ideas and she's going into hybernation soon so in the spring I will probably replace the cable to be safe I agree nothing lasts forever
Old Nov 20, 2015 | 10:08 PM
Brass Pass's Avatar
Brass Pass
Glad it was a simple fix.
To No reverse
