79 Electric Clock; future trouble maker ??
1. What if that clock had failed with the points closed. Would the coil have finally overheated and maybe caused a fire ? If the clock failed with the pints closed, would that not run down the battery if the car was not run often.
I am thinking about not putting the clock back in but replacing it with a useful instrument that wont cause me headaches.
Does anyone know of a vacuum gauge that has the right silk screen face that would somewhat match the other gauges ?
8Valve
8Valve
At the worst it would blow the fuse that feeds it. You can buy quarts movement repair kits to update your clock (about $90) or you can buy a new clock with the quartz movement already installed. The new clocks operate very smoothly with no "CLICK" every minute and the second hand runs continuously. I converter my '71's clock to the quartz movement about 5 years ago and I am very happy with it.
it out again.......not on my priority list now....doin' other "necessary schtuff"!!
8Valve
Worst case is you'll blow the fuse...
If it were my car I'd buy the quartz kit and convert it yourself. It's very easy and I can show you how!
