Header/Sidepipes vs headers true duals
Wanted to say as well, a simple head and cam swap can tax a small primary header quickly, a big header may not be tuned for off idle scavenging but it is less detrimental on the low end than too small corking things on the top end.
Do you have any understanding of these scientific principles you claim no-on reads? Do you have test data that shows adding only backpressure adds power? Do you have any data that shows backpressure helps? NOT how tuning the flow and length helps even though it results in a smaller size of pipe. How backpressure ALONE helps.
Here I'll help you out. Look at the end of the post with the butterfly flow restriction tests vs dissuser tests. Any backpressure added hurt.
http://www.mustangevolution.com/forum/f312/t296628/
Here's a good explanation of the whole concept.
http://forums.mightycarmods.com/show...why-it-s-wrong
I suggest you do some reading. Use Google and find more information. Then, you can claim you understand something instead of just going on about how it's been that way forever even though you couldn't explain why it's been that way forever.
You actually want a vacuum occurring at the correct time and in the correct location to help suck the exhaust gases out of the engine. You do not want a restriction to the exhaust gases flowing out of the engine.
The other thing that is wrong is you are reading a mustang site. You can forget about anything those guys claim
Of course, jump right to the stupidity of discounting and make fun of the link that has dyno graph proof how you are wrong.
I shouldn't have expected anything less since you have no proof, not even an attempt at an explanation why.
Well even better, we all know that DYNO's NEVER lie!!
You come across as someone who has gathered all your info off the internet (where half the posters are clueless as well). I've learned the majority of what I know in the last 30 years talking to other racers in the staging lanes while waiting to race, and actually DOING it at the track, over and over and over. I guarantee you that will will learn ALOT more practical knowledge that way...
Having a Mechanical Engineering degree and 25 successful years in the engineering field help, but I don't like to play that card much if I don't have to.
As I said, can't explain it it yet claims to be the expert by putting down proof....
Your dyno lies comment is ridiculous. A dyno is a perfect tool when doing back to back runs to determine what effect changes have on a vehicle. Just further shows you have no leg to stand on so you have to resort to discrediting.
I don't really care because the the backpressure believers are about as bad as religious zealots.I just don't want other people falling for their un-explainable crap.
And I agree with the post a few up. Any decent mechanical engineer would know you don't want to purposely add any kind of restriction to the flow of exhaust.
I will also say that any decent engineer would know that there is a technical explanation for what occurs. The excuse that it's just the way it is and no book smarts can explain it is nothing but pure BS.
You believe it and have claimed your an engineer so why can't you explain it?
By the way, when are you guys going to come get this little punk justin beiber? you can have him back.
Do you know why we have some of the most power, lowest emission and most fuel efficient engines today? Engineering of the engine and associated systems. As examples, Intake manifold simulations to create better intakes. Head and combustion chamber simulations to create MUCH better heads and piston crowns. Exaust simulations to create better exhaust systems. The simulations go as far as simulating the air and fuel mixture from the injector or carburetor going through to the chamber. It's not voodoo science that can't be explained or a case of it being "learned in pit lane".
You claim that no-one can understand it explains why you don't.
Now see what you created cable, another pipes vs duals and exhaust war...
That was my 81, it had the combination you described above.
Long tube Hooker Super Competition hedders, 2,5 duals and Flowmasters.
That would be the correct description of what it did, definitely very mean and very loud.
BUT - that was with a Hardcore Engine.
Solid Cam, Dart heads, high revs / no low end.
Supersweet grumpy idle and it really screamed - goosebumps.
I think both pipes and duals will sing you a sweet song each one in its own way, but with a stock motor will not be same fascinating.
Keep in mind the Flowmasters don`t have the deepest tone if that is something you`re looking for.
If you think back pressure helps your car at low speed smash your pipe 3/4 closed with a hammer and drive it only at low speed.why do you guys argue over stuff like this none of you will convince the other because changing your mind admits your wrong.
Back pressure never helped anything.
Like I said, it's all about speed and pressure.
