my restomod
I only make 370 lb/ft and 200 HP at 2800 with a 3.08 and it does just fine.
OP, Really nice job all around. Engine bay, interior, exterior, paint, it all looks great!
Transmission / Drive line
• T56 Magnum 6 speed transmission
• 3.73 Differential
1st 2nd 3rd 4th 5th 6th
2.66 1.78 1.3 1 0.8 0.62
9.92 6.64 4.85 3.73 2.98 2.31
Dart SHP 400 block - bored .30 over - CR 10.8
Callies Dragon Slayer 3.875 forged crank
Super Victor intake manifold – ported, port matched and powder coated
AFR 195 Competition Eliminator heads - ported and port matched
Wiseco Pro Tru Forged Flat Top pistons -5.4cc
Comp Cams Hydraulic Roller Cam 242/248 - .603/.562 - 110
Crower SS shaft mounter rocker arm system. Rocker Ratio 1.65/1.55
Morel Hyd Roller lifters
Scat Pro Comp 6" 4340 forged rods
Quick Fuel Q-750 Carburetor
MSD 8361 Distributor 6AL Ignition Control Box and Coil
Cloyes Aluminum Timing cover
Cloyes Timing chain and gear
Milodon 7 qt Street Strip Oil Pan
ATI Harmonic Balancer
RobbMc high volume Fuel Pump
RobbMc high torque mini Starter
Restored L82 aluminum valve covers
Custom CNC Billet aluminum valve cover spacers - to accommodate rocker arm system
March serpentine system
Edelbrock High Volume Aluminum Water Pump
• 3.73 Differential
Transmission Gearing 2.66 1.78 1.3 1 0.8 0.62
Final Gearing 9.92 6.64 4.85 3.73 2.98 2.31
Brakes
• Hydratech Hydroboost braking system
• Wilwood master cylinder
• SS brake lines
• Proportioning blocks
• Brake hoses
• Semi Metallic Brake pads
• Brake Calipers - Stainless Steel Sleeve, O Ring Piston
• Rotors and Bearing Assemblies
Suspension
• Tubular Upper A-Arms w/ Moog Ball Joints
• A-Frame Rebuild with Moog Ball Joints, Powder Coated
• Smart Struts
• Poly Bushing Pinion kit
• Front Sway Bar Kit,1-1/8"
• Rear Sway Bar Kit 5/8 Solid
• Bilstein Sport Shocks
• Front Coil Springs, Powder Coated, Gymkhana – 550lbs/in
• 330lb Rear Composite Monospring
• Half Shafts
• Trailing Arms
Steering
• Borgenson Steering Box Conversion (12.7:1)
• Moog Tie Rod Ends
• Moog Idler Arm
• Rag joint
• Steering wheel conversion kit
• Leather wrapped wheel -Tilt Telescopic style
Wheels and tires
• BFG Radial TA (255/60/15)
• Original aluminum wheels (Stripped, cleaned and polished)
• Aluminum Wheel Caps
Fuel
• 74 Gas Tank and hardware
• Fuel Tank sump
• 1/2" SS fuel line
• RobbMc high volume Fuel Pump (550 HP rating)
• Fuel sending unit
Exhaust
• Stainless Works SS 1-3/4-inch long-tube headers
• Allen Stainless SS exhaust pipe, mufflers, tailpipes
• SS header collector adapter
• SS Exhaust band clamps
• Exhaust H pipe
Cooling and AC
• Vintage Air Conditioning System
• Dewitts Aluminum Radiator w/ twin elec fans
Paint and Body work
• Strip car, Fix cracks, dings, smooth out bonding strips, Block body
• 73 Front Bumper bonded and blended to body
• 74 Back Bumper bonded and blended to body
• Fabricate fiberglass exhaust bezels
• Prep and spray gelcoat, Prime and Wet sand
• Undercoat wheel wells
• Apply base and clear coats
• Cut, Buff, Wet sand and polish car
Chassis
• Sandblast and Powder coat Frame
• Body Mounts
• Gforce Transmission Crossmember
Misc
• Wiper Motor / Arms
• Splash Guards / Dust Shields
• Overflow / Recovery tank
• Washer Fluid Tank
• 80’s Style Seats (Leather seat covers, foam, seat frames, tracks)
• Replacement Door panels
• Door handles
• Dash Pad
• T Top Head liners
• Center Console
• Instrument Cluster
• Restore Clock
• Carpet
• Weather stripping
• Heat/Sound barrier
• Side Mirrors
• 72 Removable Rear Window and tray
• Retro Radio (Bluetooth, USB, MP3)
• Power antennae
• High performance speakers (dash and kick panels)
And I say this because a dyno test was done on a sbc 427 nothing altered at all except carb,started with a 750 and went to 850 and the hp gain was sorta shocking all of 20hp and better torque . And it was on the climb but as you can see the test stopped at 6200
Of course I can not say that will work with your set up but 750 seams a bit small for that set up your running.
• 3.73 Differential
Brakes
• SS brake lines
• Brake hoses
Suspension
• Smart Struts
• Half Shafts
• Trailing Arms
Steering
• Moog Tie Rod Ends
• Moog Idler Arm
• Rag joint
Wheels and tires
Fuel
• Fuel Tank sump
• 1/2" SS fuel line
• Fuel sending unit
Exhaust
• Exhaust H pipe
Cooling and AC
Paint and Body work
Chassis
• Body Mounts
Misc
• Washer Fluid Tank
• Door handles
• Dash Pad
• T Top Head liners
• Center Console
• Restore Clock
• Carpet
• Weather stripping
• Side Mirrors
• Power antennae
............and the front centre grille that replaces the license plate frame?
https://www.youtube.com/watch?v=zeuTaefOIgI
BTW - I am in upstate NY near Saratoga. I went right by you on my way home from South Dakota when I was driving the car home about 2 weeks ago.
Having trouble finding anyone to tune this carb in my area. Does not like to idle below 2000. Any suggestions?
