Help with Fluid Changes
Old Dec 7, 2015 | 11:05 AM
x IRON EAGLE's Avatar
x IRON EAGLE
Default Help with Fluid Changes
The last time anything was changed in my 76' besides the oil was about 20 years ago.
I'm looking at changing the following:
Brake Fluid
Power Steering Fluid
Transmission Fluid/Filter (Turbo 400)
Rear Differential Fluid
Can someone help me with the fluid capacities as well as what their recommendations would be for the best fluids/weights? Looking at going all Amsoil right now.
Old Dec 7, 2015 | 11:22 AM
croaker's Avatar
croaker
If you have owners manual I think capacities are listed in there. If not a Chiltons or the like does. Either would be a good investment.
Old Dec 7, 2015 | 01:23 PM
lurch59's Avatar
lurch59
I agree with the Amsoil choice, you can't go wrong there...
Old Dec 7, 2015 | 08:18 PM
Peterbuilt's Avatar
Peterbuilt
Brake Fluid- DOT 3 if stock, buy a quart, clean out the M/C, refill with new fkuid and bleed from there.
Power Steering Fluid -20 oz's. Just buy a quart.
Transmission Fluid/Filter (Turbo 400) 7 1/2 pints. Ad 5 pints and with the transmission up to operating temperture top up but with a maxium of 7 1/2 pints. Do not over fill.
Rear Differential Fluid - Put in one bottle of 'GM limited slip axle lubricant additive' and top up to the bottom of the fill hole with 80W90.
Hoes this help?
Old Dec 7, 2015 | 10:19 PM
7T1vette's Avatar
7T1vette
20 years????
Old Jan 29, 2020 | 02:24 PM
corvettejoe09's Avatar
corvettejoe09
Just 2 days ago I was thinking the same thing that OP was questioning but only with the drive belts & the power steering fluid. Since I do HPDE, I'm over due with these 2 items. Mine is an 09.
I did come up with the 10 years for the belts too.
Old Jan 29, 2020 | 04:37 PM
Tampa Jerry's Avatar
Tampa Jerry
Don't forget a coolant flush. Jerry
Old Jan 29, 2020 | 11:46 PM
7T1vette's Avatar
7T1vette
A bit late, guys. It's a 5 year old thread....
To Help with Fluid Changes
