Simple wiring harness?
I have had wiring issues for the last five years. I have had it with the hacked wires and all the issues. I am contemplating removing the old wiring harness and make my own from scratch. Has anyone done this? A new harness for stock setup can be up to 2k but I need very few items from the stock harness.
My logic is I need windshield wipers, headlights, taillights, fuel pump and power to accessories. What else is there? When I upgraded the headlights I build my own harness for them and the LS1 has its own custom harness too. Only a few wires plug into the power system of the car.
If anyone has some input, wiring diagrams or something like that I would highly appreciate the help.
Ron Francis expensive but nice.
I used EZ wire 22 circuit, instructions are the best and you will need to run additional wires for to complete some circuits as they werent in the kit. I have a post on here somewhere about the install.
And...for what it is worth so we do not hear you scream in the future. IF you replace the wiring form a company that is NOT using GM design and colored wires. I hope you take the time to make your own wiring schematics...so IF something goes wrong...you have a way to find the problem...because if the wiring is different...using a GM wiring diagram is going to be useless.
DUB
I happened to have couple old harnesses and spent DAYS extending and fixing up everything from the fuse box. One was from a vette, one was from a 65 Impala. I added a plug so the center gauge console can be unplugged and the gauges can be bench tested.
AND keeping GM colors so the wiring schematic is same as original!!!
One from scratch- that will take some serious time-a lot of different colored spools of wires. Um- turnsignals...horn...brake lights..Gauges...ignition switch
Don't know your definition of simple...but even I wouldn't call it that!!!
A Painless Classic car customizable is about $600...might be a lot easier to buy an OEM dash harness for less and just redo under the hood as you have a LS.
I wouldn't throw the baby out w/ the bath water- unless you are doing a track car...
I kept the OEM harness- and basically used it to trigger relays and added my own "sub panel"
And like Dub said- MAKE a wire diagram- use same wire colors through out. Like I used purple - same color GM used off the ignition switch for the starter wire.
ECU fuse panel by Richard Hayes, on Flickr
DSCN5030 by Richard Hayes, on Flickr
DSCN5177 by Richard Hayes, on Flickr
except the chrome bumpers and maybe the door handles....
BTW, I buy no wire new, it's all tear outs from decades of cars/hotrodding, GM wiring except for the annoying white molex plugs in later sharks, and the bulkhead main wiring harness connector, I wire direct around all that crap.....the only parts of my harness that are stock are the front and rear lights, even though the lights on either end are not stock.....
OP, sounds like it's not a problem for you, really....just get a few diagrams from Wilcox or whoever he recommends and you be on your way......My son did an LS into a '57 Chebby pickup, and is he can do that without NEAR my electronic background, and you did the same thing, essentially.....feel free to PM me if you want, but it's not the big deal......
The harnesses with a fuse block typically come with the wires kind of pre-bundled how they expect it to route. I completely undid all the bundling and separated all the wires so I could re-routed the wires to go the direction I wanted as they left the fuse block.
Mount the fuse block and then route all the wires. Work from the fuse block out. Tie wrap the wires where you want them to route right up to the connector/switch/terminal they terminate at. Cut them long to get rid of the gross excess but make sure there is enough in case adjustments to the harness routing are necessary. Once you get the harness routed, go back and start terminating everything. You'll find you start routing and then have to cut back and adjust.
Make sure the harness routing clears the dash/radio/gauge cluster etc before you start terminating.
The terminals are usually Packard type. You can buy them in different places but they are a little hard to find. The source I used is gone and I don't have another offhand. I bought different terminals and connectors for everything and it was probably $100 or so just for for those extras. There are good ratcheting crimpers on Ebay that work to install the terminals.
SO...unless a person KNOWS what they are doing and STOPS and thinks about FUTURE SERVICE work...I would advise replacing the wiring harness with the correct factory replacement. Because getting on the level of what 'Richard454' is doing takes a person who KNOWS what they are dong and is NOT in a hurry to get there. I am NOT 'saying' that people can not do wiring....but from my experiences in having to repair electrical repairs...they fall short of doing it RIGHT and do whatever just gets them by.
DUB
If it is a custom install like what 'Richard454' has shown...then I am buying bulkhead connectors and special connectors/relays and all that so the wiring is taken to the next level and very service friendly.
DUB
Almost none of the universal wiring kits come with a bulkhead connector. AAW update kits and one of the Painless kits are about the only ones.
For me it was completely pointless to buy a factory replacement harness then cut it up to make it work. That just made no sense. A universal wiring harness with a bulkhead connector was abut 3X what a kit without cost making the decision to go without easy. Routing the wires properly and there is no need to disconnect at the firewall until it's time to replace the harness again.
http://www.btcelectronics.com/spec-a...c-44-l-en.html
The problem that I have with many of the aftermarket bulkhead connectors is that the gauge wire size is limiting me in doing what I want when I have massive power through the firewall. Or the number of terminals in them are too low and is not going to work.
I use or Chaney up the bulkhead connectors with more terminal slots using GM bulkhead connectors. Due to as I wrote before..I can crimp on the factory terminals and cage them...and move on from there.
DUB
I know Peter (Lionelhutz) wouldn't think of using these really nifty connectors -as they came off a German engineered car.
But I have found them pretty useful- and basically cost nothing off parts cars.
Funny story from some...jeez....almost 40? years ago....'72 Lemans/Pontiac at DCA airport picking up the kid's mom/my ex's Mother for the introduction so the ex goes to greet her mom and I set on the street/drive around....radio on, and so they load up and I go to start the car....
short form, 10 pm, borrow a flashlight from a guard, pull out crap from the trunk....jumper the coil, and the headlights with a lighter weight to the coil, and a major jumper cable I still have....from the fuse block to the underhood enough to drive the ~20 miles home
for some odd reason the old lady was impressed, ME feeling like an idiot.....
never did find out WTF happened to that car.....sold it years later.....
I could have re-used the factory bulkhead connector but it uses the twin-lock connectors and I'd rather pass straight through then use them.
I'd also rather pass the main heavy gauge power feed straight through before spitting it to multiple connector pins. Doing that just adds a measure of bubba to the car.
Overall, I just don't consider having a bulkhead connector to be that important. Running straight through is also the simplest and most foolproof way to do it.
Two different ways of thinking and depending on the person...and HOPEFULLY whoever install this style of wiring harness stops and thinks about repairs/diagnostics...SO...both are correct. I myself...as I stated before...want a bulkhead connector that I can access so I do not have to tear a car apart to repair a wiring fault or just being able to access it to run diagnostics. I always stop and take time to think when installing something....because working on these Corvettes when if ONLY the designer STOPPED and took a minute to think about repairing it AFTER it was built...instead of thinking ONLY (assumption) about the speed to assemble it...my life would be a bit easier on some service operations.
DUB
What I have decided to do is replace my old harness with a universal one that has all the items I need. I will have to extend a few wires and wire the connectors on some of them which is fine by me. Plus, I met a guy who rewired his c3 and we started talking about the wiring issues. After a while I ended up at a hot rod shop and had new harness for 280 bucks.
I found 4 places that may have been causing my direct short for the fuel pump and I really really really hope it's not the Dakota digital board.
Today I have removed the harness from the entire car except the ls1 harness. I found wires changing color up to 4 times! Bare wires and some other Bubba stuff.
Let the fun begin and I finally get to use my label maker
