Driver door won't open..
Old Dec 8, 2015 | 11:26 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Driver door won't open..
Yesterday, I tried to open the driver side door and it acted like it was locked...just went down. I had to open the passenger side door and open the driver's side door from the inside. I removed the door panel, the plastic barrier and the access panel and tried the outside door latch while looking inside the door...NOTHING MOVED. Can't find the vertical rod that the door latch is attached to and opens the door. It's not where it's supposed to be NOR is it anywhere in the door! It's worked perfectly since I had the car (15 years)..now this. HELP!!!
Old Dec 9, 2015 | 05:30 AM
toobroketoretire's Avatar
toobroketoretire
The rod is in there somewhere.
Old Dec 9, 2015 | 11:54 AM
Tychamon's Avatar
Tychamon
Take the metal cover off at the bottom of the door so you can reach inside with a magnet or grabber tool. I'sure it fell down in the door.
Old Dec 10, 2015 | 01:04 AM
7T1vette's Avatar
7T1vette
What he said....
Old Dec 10, 2015 | 02:25 AM
slickfx3's Avatar
slickfx3
welcome to the locked out club, you have been hazed and initiated, wear your c3 proudly
let me know when you are a double awarded
Old Dec 10, 2015 | 02:28 AM
slickfx3's Avatar
slickfx3
telescopic magnet and grope
Old Feb 23, 2016 | 12:22 PM
croaker's Avatar
croaker
Did you find it?
Old Feb 23, 2016 | 02:29 PM
VancouverL71's Avatar
VancouverL71
Originally Posted by croaker
Did you find it?
I just replaced both of my door handles this week on my 1969. The bottom of the handle where the rod attaches on one side simply sheared off. Though there are two different types of clips that hold the top of the rod and the bottom of the rod, after 40 years they may have fallen off.
All I can say is I hope your hands are not too big, both my hands are cut to shreads having just finishing both doors, neither which would open probably explaining why the back window of my convertible top was cut out! Don't give up, mine finally are operating like new!!
Good luck
Pete
To Driver door won't open..
