Ball Joints
Old Dec 17, 2015 | 02:44 PM
Vettesic's Avatar
Vettesic
Default Ball Joints
Doing front end on my 71. All safety measures in place for coil spring removal. Got all off except for rotor assembly that attaches to upper and lower ball joints. I've tried pickle bar with no budging. Any suggestions at this point would help.
Old Dec 17, 2015 | 02:55 PM
hugie82's Avatar
hugie82
You can whack the flat edge were the ball joint slides into the spindle. I usually leave the nut on the ball joint loose and using the spring load on the ball joint to pop it apart. If you have the spring out, use a little heat and beat the **** out of it with a pickle fork. You won't be ruining anything you're not replacing anyway.
Old Dec 17, 2015 | 03:51 PM
62corvette's Avatar
62corvette
I know what you are going through. Just did that about 2 weeks ago. I used aft/acetone mix and soaked it for two days. Then used Harbor Freight balljoint separator tool. That worked, but still came apart hard. It went together in December of 1970, and was reluctant to come apart. Good luck.
Old Dec 17, 2015 | 03:58 PM
redvetracr's Avatar
redvetracr
bigger hammer
Old Dec 17, 2015 | 03:59 PM
ddawson's Avatar
ddawson
The pickle may be too long. Plus use a 5 pound sledge.
Try sliding an open end wrench in there to give the fork more thickness.
Old Dec 17, 2015 | 04:07 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Make sure you're using a ball joint separator and not the smaller tie rod end separator. The small fork will hang on the width of the ball joint stud preventing you from driving it in far enough to wedge the rotor joint off of the ball joint stud.
Old Dec 17, 2015 | 04:10 PM
Roadster71's Avatar
Roadster71
I used a wrench as a spacer under the pickle bar too. Once I did that it only took a couple good hits to break free.
Old Dec 17, 2015 | 04:51 PM
Vettesic's Avatar
Vettesic
I think fork is small for this job. I'll try to squeeze open end wrench in there tomorrow. Or I'll get larger ball joint toll. Annoying.
Old Dec 17, 2015 | 04:54 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I personally like using the OTC tie rod or pitman arm pullers. They work like a press and push in the middle. Look for the 3714A.
Old Dec 17, 2015 | 05:51 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Harbor Freight Ball Joint Tool
I'm not a big believer in cheap tools, but the ball joint separator from Harbor Freight works.
I!ve used it a couple of times and it hasn't broke.
Bob K.
Old Dec 17, 2015 | 06:16 PM
mortgageguy's Avatar
mortgageguy
I just did this about three weeks ago. The bottom joint was tough, work on getting the upper to break loose, get the knuckle off, after getting spring out, and then you can work on the lower on your work bench.
Old Dec 17, 2015 | 06:43 PM
Swiftrider08's Avatar
Swiftrider08
Bob K.
Totally agree. Tool works great. No beating on anything and they popped right loose. Easy.
Old Dec 17, 2015 | 08:49 PM
Vettesic's Avatar
Vettesic
Bob K.
Is that a press or fork?
Old Dec 18, 2015 | 12:17 PM
gungatim's Avatar
gungatim
trick ive posted before I learned from my BIL who is a GM mech at dealer.
you get an air chisel, put in a flat round bit (grind or make one if you need to). and hammer the side. it will pop right out.
Old Dec 18, 2015 | 04:56 PM
Bob K's Avatar
Bob K
Default It's a hand tool
It's a little set of jaws that spread apart with a bolt.
Bob K.
Old Dec 18, 2015 | 06:14 PM
Big Block Dave's Avatar
Big Block Dave
Bob K.
I feel the same way, and used the same tool for the job. It was probably on the verge of breaking, but it did get the job done.
Old Dec 19, 2015 | 11:26 AM
Vettesic's Avatar
Vettesic
Ok. Got them all off! With the help of forum members. Got the tool from Harbor Freight as directed. Uppers not to bad. Lowers were real hard. Took within an inch of the tools life but they finally popped. Had to relocate tool several times. No pounding what so ever involved. Forget pickle fork. Use this tool is lots easier. Now to get lower control arm bolts off.
Old Dec 19, 2015 | 05:44 PM
mortgageguy
Now the fun is reversed. The lower control arms are easier to get off than the upper. The upper on the passenger side is tough.
To Ball Joints
