Mild 454 Engine Build
Old Dec 21, 2015 | 12:24 AM
Vortecpro's Avatar
Vortecpro
Default Mild 454 Engine Build
I thought I'd share a recent 454 build with your forum. Built for a 1971 Corvette, although not a correct restoration type build but a every day driver build. Compression turned out right around 9.4 along with a 228 @ .050 hyd roller, A 781 oval port head was used with a 2.190/1.880 valve. The factory cast iron intake was used with a Q-Jet. It will be interesting to see what kind of power this type of build will make for power, I will follow up with a dyno test. Some pictures.
Old Dec 21, 2015 | 12:28 AM
454Luvr's Avatar
454Luvr
Nice looking motor. If your goal is street torque, you really should consider an aftermarket aluminum intake and a smallish Holley or Edelbrock.
Old Dec 21, 2015 | 01:26 AM
bluedawg's Avatar
bluedawg
What do figure it will make?
Old Dec 21, 2015 | 06:08 AM
96 lt-4's Avatar
96 lt-4
I agree with the aluminum intake(painted of course) but I would keep the Q jet.No way a 600 Holley/Edelbrock belongs on a 454.
Old Dec 21, 2015 | 06:48 AM
530planeman's Avatar
530planeman
Hi
First of all I wish you would clean up you shop lol. Let me know how it comes out I am getting ready t rebuild my 454 same year '71 a Quadra jet will work fine may need to change metering rods .
Merry Christmas
Old Dec 21, 2015 | 07:59 AM
Vortecpro's Avatar
Vortecpro
I really don't know, but were going to find out today.
Thanks for the replies.
Old Dec 21, 2015 | 08:14 AM
ajrothm's Avatar
ajrothm
Looking good Mark!
I'm sub'd to see what you make with that stock intake... I assume you "tweaked it"...LOL.
I'm calling it.. 535hp/550TQ.
Old Dec 21, 2015 | 08:18 AM
zwede's Avatar
zwede
Will be interesting to see if you can make it make power above 5,000 rpm. That was the problem I had back when I ran the stock intake manifold. Will you run headers or manifolds?
Old Dec 21, 2015 | 08:29 AM
Vortecpro's Avatar
Vortecpro
Originally Posted by ajrothm
Looking good Mark!
Thanks Alan, I run full length 2 inch headers with mufflers on the dyno.
Old Dec 21, 2015 | 10:28 AM
454Luvr's Avatar
454Luvr
It's much more difficult to tune a Q-jet than a Holley or Edelbrock. I know this from experience with my own '72 and '73 454 Vettes. The Q-jet can be an excellent carb, but you'll be many hours ahead if you start with something else (Holley is the easiest, although the Edelbrock tune kits make theirs a close second). Contrary to popular opinion, 600-650 CFM is NOT too small for a BB on the street. Calculate the flow through the motor at 4,000-5,000 RPM (and compensate for average volumetric efficiency) and you'll see what I mean. Street acceleration with a carb this size can be truly amazing, I used to pull the front wheels off the ground. A larger carb won't meter as well at lower RPM, will cost you torque and fuel mileage. Speaking of which, a 650 double-pumper will really get your attention on a motor like this, but fuel mileage will suffer quite a bit compared to a vacuum secondary carb.
Have fun!
Old Dec 21, 2015 | 10:55 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Have fun!
The only reason the DP will use more fuel is because someone is having too much fun playing with it and enjoying the power.
If you're never going over 5000 RPM...maybe a 650 is sorta OK....but I'd use 750+ cfm all day long...especially on a dual plane intake on a motor that has better heads and cam for sure.
When going WOT an individual cylinder...and the rapidly following next ones with a dual plane only "sees" 2 BBLs vs a single plane that has access to all 4.
I'm betting on the capability for an 11 sec time slip in the right C-3.
JIM
Old Dec 21, 2015 | 11:30 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I say about 360-370 horsepower....420 ft/lbs. torque....the low rise intake is a HP killer.....
Please do not use a square bore carb on a Q-Jet manifold.....even the best spacers have a horrible mismatch that not only is detrimental to flow....but wreaks havoc on tuning....
It should run great with a Q-jet.....you will have a lot of fun with it.....lots of torque down low
Jebby
Old Dec 21, 2015 | 11:39 AM
69ttop502's Avatar
69ttop502
Jebby
Jebby, if you are not familiar with Mark (Vortecpro), he is a fantastic engine builder that always seems to do way better than the sum of his parts lol. He works magic on the old oval port heads though not sure he worked his magic on this build. Will be interesting to see.��
Old Dec 21, 2015 | 11:43 AM
Kid Vette's Avatar
Kid Vette
454Luvr, 96 lt-4, you guys realize you're giving tips to a professional engine builder with a reputation for building phenomenal big blocks, right?
Old Dec 21, 2015 | 11:44 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I don't no...sorry.....but if he is as savvy as you say...there are plenty of tricks in these engines that will make power beyond its look!
Jebby
Old Dec 21, 2015 | 11:47 AM
454Luvr's Avatar
454Luvr
FWIW, the console plate on my '72 said "455 lbs/ft." Compression was 8.5:1. You can only go up from there!
Old Dec 21, 2015 | 11:48 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No I did not......but if he is professional, he will read it and smile....like I would.
I guess I am a professional engine builder myself......with a reputation for building phenomenal Big Blocks....but it just didn't pay...and I got older.....still love building engines...just not for a living.....
My hats off to Mr. Mark for putting together what I am sure is a fine Mark 4
...now for that dyno sheet
Jebby
To Mild 454 Engine Build
jkippin's Avatar
jkippin
too funny I need to watch this post I am interested to see his FWHP should be a good eye opener for some.
Mark does really nice work ive heard of him once or twice.
Old Dec 21, 2015 | 11:59 AM
454Luvr's Avatar
454Luvr
Hey, the big blocks I've built were phenomenal too! If not for the thieves that put me out of business, I would have had a twin-turbo 454 Vette on the street back in '77. The hot-rod hobby attracts a lot of despicable people, I learned that the hard way when I was young and stupid. Anyway, I'm hoping the OP will post progress and results for this build. It's amazing what a near-stock BB can do in the right hands!
Old Dec 21, 2015 | 12:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It most certainly does.....
One of my mentors....built IHRA Top Stock engines....talk about dirty tricks!
Yes...popcorn on the OP.....I am probably way off.....
Jebby
