Upper control arm- drilling for weight loss
Old Dec 23, 2015 | 06:01 PM
73C34me's Avatar
73C34me
Default Upper control arm- drilling for weight loss
Anyone drill holes in an effort to reduce the weight of stock upper control arms? They appear beefy, thinking of using a 1-1/2"ish hole saw to drill an area out of the center of the horizontal triangular area. Then perhaps. Couple of 7/-16" ish holes int the vertical lip area close to the cross shaft. I have seen this done years a ago and wouldn't do it on a daily driver. The aftermarket lite weight arms seem slightly flimsily and expensive for the minimal savings in weight. I have tubular lower arms with the mono spring conversion. I don't have a control arm near by to reference, so hole sizes are approximates. Thnx
Old Dec 23, 2015 | 07:56 PM
Sayfoo's Avatar
Sayfoo
How much weight could you possibly save?
And what would that help?
Old Dec 23, 2015 | 07:58 PM
COOLTED's Avatar
COOLTED
I've seen it done on some drag cars, but I can't imagine it would save more than a few ounces.
Old Dec 23, 2015 | 08:07 PM
Kacyc3's Avatar
Kacyc3
doesnt sound safe, why not look into those alum arms one of the vendors has?
Old Dec 23, 2015 | 08:15 PM
ddawson's Avatar
ddawson
"minimal savings in weight"
Its several pounds difference from stock to the aluminum.
Bee Jay shows a difference of 13.5 pounds each, 27 total.
Old Dec 23, 2015 | 09:08 PM
AW IR C3's Avatar
AW IR C3
Old Dec 23, 2015 | 10:48 PM
3JsVette's Avatar
3JsVette
I can't imagine the weight savings is worth the possible safety risk especially on a street car. Aftermarket arms I think would be a better way to go if you feel it's a must.
Old Dec 24, 2015 | 02:12 AM
454Luvr's Avatar
454Luvr
Bubba has done this.
Old Dec 24, 2015 | 02:23 AM
slickfx3's Avatar
slickfx3
it's cheaper than willwood calipers
one saves your life the other may get you killed
Old Dec 24, 2015 | 04:21 AM
kenmohr's Avatar
kenmohr
Old Dec 24, 2015 | 07:55 PM
vettefred's Avatar
vettefred
Skip Shift
Check out a set of tubular arms. Compare the weight of one of those to the stock arm. I think you will see a slight weight savings. Certainly more than drilling the holes in a stocker and much safer for you.
Fred
Old Dec 24, 2015 | 08:05 PM
Shovels and Vettes's Avatar
Shovels and Vettes
How about not eating a Big Mac before you go driving, and you will be better off.
Old Dec 26, 2015 | 10:47 AM
1974CorvetteJimCr's Avatar
1974CorvetteJimCr
seriously ?!?!?!
Old Dec 26, 2015 | 11:33 AM
73C34me's Avatar
73C34me
Merry Christmas guys! Thnx for the input. I agree w/ all of you. Having said that, my whole car is "bubba'd". So I may place a couple of small holes... To add interest! Thnx. Someday lite weight arms for sure!
Old Dec 26, 2015 | 05:40 PM
rcread's Avatar
rcread
Any hole you put in the control arm will compromise structural rigidity. Don't do it.
Old Dec 29, 2015 | 06:20 PM
BOOT77's Avatar
BOOT77
VBP a-arm 4.5 each
stock 9 each
https://www.corvetteforum.com/forums...m-install.html
Figured I'd save someone from being mislead.
Old Dec 30, 2015 | 04:13 PM
71coupe's Avatar
71coupe
I put a pair of these on my car a few years ago.
Best single improvement to date for handling & lighter too. I think my caster is between 6-7 deg now + the modified lower roll center.
https://www.vansteel.com/index.cfm?f...owItem&ID=3697
To Upper control arm- drilling for weight loss
