I finally ordered a set of upper A Arms from Vette Brakes and Products. I went with the Hi Performance Arms with aluminum cross shafts. The Arms weigh only 4.5 lbs each with ball joint. That's 9lbs total.
I had the stock factory A Arms out in about an hour. They weigh 18lbs with ball joints. I'm going to lose 9 more pounds, and gain some castor. I'll finish installation tomorrow.
Im sorry to say but i have had some bad experience with those contoll arms..
I adressed VBP about the problems but they just ignors me..
Those controll arms are weak and can absolutely NOT be compared with the stock ones.
The bushings are not supported both ways by the aluminium cross witch leads to that only ONE of the bushings takes the force when braking.
On my car the controll arms simply got bent and the result was that tey got slack.
Watch my video of my controll arm after a quite mild trackday on stock road tires.
My controll arms is now hanging on a Nail on the garage wall and are relpaced by a different brand from a different Company since VBP dont appear wanting to sort their crap out.
I called VB&P about the problem after you had that video on here the first time. I put a set of these on my car but haven't got it on the road. They said I could send them back and exchange them for the earlier braced style.
I decide I am going to fix them myself. The stock arms are not supported on the inside either, especially if you install poly bushings. It is the arm itself that needs to be stiff. I've already plotted out how I am going to triangulate the bracing on the arms. I will use chromoly tubing so they will be very stiff but not gain much weight. I don't like the square tubing VB&P used on the earlier arms.
Im glad that you have managed to have a duplex communication with them, something i have not been very successful with.
I have spent some cash in the VBP shop and it would be nice if someone from VBP contacted me and actually wanted to make up for those weak control arms.
Until then I have stopped spending my money at VBP.
Before installing the VBP control arms, replace the low quality ball joints with some Moogs or other better quality stuff.
Saves you the job of having to take everything apart and do it the next summer..
X2. Did the same on the VBP upper arms (older not tubular ones). The weld of the eye to the rest is not strong either. I had to reïnforce mine.
BTW : I went back to rubber all around and with the gymkhana type springs the thing is stiff. It will rattle my teeth out when driving over a bad road. I cannot imagine what it would have been when there would be poly's.
I wish I had seen this before I ordered. I've been doing business with VB&P for decades. When I ordered these, I was told they would ship tomorrow. When I called back two weeks later, I was told that they were on back order and maybe I'll get them by the end of the month. I got them two months later. Maybe they were re engineered or redesigned. I hope so.
BJ: Other than the weight loss, what will the increased castor accomplish?
Please let us know how it works out.
I have thought about this,
but wonder if the improvements
are worth it?
R
The increased castor gives increased straight line stability and a quicker return to a centered steering wheel. When you move the stock Corvette steering wheel, and release it, the steering stays in the turned position, and the car continues to turn. My daily driver is a Porsche Boxster, when I release the steering wheel from a turned position, it immediately returns to straight. When on Corvette cruises, I noticed most of the C2 and C3 drivers constantly correcting, or sawing on the steering wheel. I will eventually install rack and pinion also.
I am sad to say but by judging from your pictures they have not been redesigned.
They look just the same as the ones I bought from them.
I am not interested in starting crusade against VBP, I simply think they should listen to their customers, the people who is buying and using their stuff and if a product does not stand up to what one may expect a good company should be interested in the feedback and correct whatever is wrong.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It was my impression that the performance benefit of additional caster is that the outside tire in a corner has additional negative camber while the wheel is turned. That enables a touch better grip while cornering. IIRC, the stock C3 geometry is pretty poor for camber on a tight (autocross) corner.
I don't recall any return-to-center complaints with the stock caster setting when I had the original suspension.
