Bee Jay's VBP A Arm install
Old May 23, 2013 | 06:01 PM
  #41
Bee Jay's Avatar
Bee Jay
Originally Posted by v2racing
I sat down and studied these VB&P arms and the C3 geometry and I believe I have come up with a fix that will also help handling.
I am going to make new cross shafts out of 7075 aluminum (I have plenty of it already) with a different mounting style for the bushings. They will be firmly supported inside and out. I will lower the arms pivot point and in doing so will lower the roll center and change the camber curve in much the same way a longer ball joint would do. I have to trig it out first, but I think this is the way to go.
Triangulating the arms would require stripping the powder coat and redoing it. I can machine these up myself with virtually no cost involved. I should be able to do it rather quickly after I make up my blueprints.
Suspension and steering guys, what do you think?
While your at it, here is some more bad news to consider. My alignment specialist just called. He can't get anything less than -1.5 degrees of camber. It's a combo of my lowered ride height and these A-Arms. The adjustable CPPs are looking better and better. -1.5 degrees of camber is what racers use, but they trailer their cars to the track. I'm driving this on the street. How bad will my tread wear be?
Bee Jay
Old May 23, 2013 | 06:54 PM
  #42
pauldana's Avatar
pauldana
Bee Jay
I run a -1.5... I do drive her a lot, although not my daly driver, but between runs, track, and just fun time around town, i probably put on about 500+ miles a month..... and I would say very little extra wear.
Old May 23, 2013 | 06:57 PM
  #43
7t9l82's Avatar
7t9l82
lowering the pivot point on the upper control arm is exactly what Shelby did on the GT 350.
Old May 23, 2013 | 09:21 PM
  #44
vette427-sbc's Avatar
vette427-sbc
Bee Jay
Not great, but not horrible either... Another benefit of the SPC arms is that with the more aggressive camber curve, you can run less static camber than normal, and still end up with the same camber under cornering. (dynamic camber? not sure what to call that)
Did your alignment guy say anything about the amount of castor he was able to get out of the arms?
Old May 23, 2013 | 11:23 PM
  #45
Kid Vette's Avatar
Kid Vette
Can't you dial up your spreader bar to increase camber?
Old May 24, 2013 | 12:24 AM
  #46
Bee Jay's Avatar
Bee Jay
Castor left 4.7 degrees, Castor right 4.8 degrees
Camber left -1.7 degrees, Camber right -1.5 degrees
Total toe -.01 degrees
Drives straight as an arrow, I haven't tried handling trials yet.
Old May 24, 2013 | 12:27 AM
  #47
Bee Jay's Avatar
Bee Jay
I reinstalled the spreader bar and cranked pretty good to spread the A Arms a little after I got it home.
Old May 24, 2013 | 12:43 AM
  #48
gkull's Avatar
gkull
Castor left 4.7?degrees, Castor right 4.8 degrees
BJ. I have really stiff front springs and when I ever exceeded about .52 camber with my 255/17/45 front tires. I got wear in the inside edge with anything over that camber with near Zero toe . Toe like .006 just to keep the front end from hunting around. My castor is also about 4.5 with my modded stock a-arms bar. at the shop I machined the steel bar holes .250 inches.
That aluminum piece is probably offset the same
Old May 28, 2013 | 12:42 PM
  #49
donyue's Avatar
donyue
They're in. I love working on this car, it's my hobby, but sometimes it's a Pain In The ***. I hope these work out. I need to get an alignment befor I can get a driving impression.
Nice job Bee Jay,
I'm am going to install my VBP upper A-arms soon as well. I have the a-arms with the steel shafts instead of aluminum. I purchased the upper and lower ball joints from VBP as well so I am hoping they will last a while before I need to replace them with MOOG balljoints.
I only expect to put less than a 1000 miles a year on the car and I won't be racing or tracking the car on a regular basis so hopefully these a-arms and ball joints will hold together. I'd rather not replace the new VBP ball joints with MOOG until I have to. If the VBP A-arms prove to be faulty then I will replace them with the SPC units as suggested.
I had read previously in this forum that the VBP ball joint problem was experienced years ago and am hoping that the VBP ball joints I have won't have the same problems. Well I suppose only time will tell.
Old May 28, 2013 | 01:23 PM
  #50
v2racing's Avatar
v2racing
BeeJay,
The problem with attaining the desired alignment specs is more than likely your frame. These frames tend to droop inward towards each other at the upper arm mount (tower). Measure between them. The stock measurement should be 26 3/8". If the measurement is a lot shorter, a frame shop can bring that back. If you have the nerve to try, which from what you have done to your car so far, I would say you do, you can CAREFULLY spread the towers with a porta-power. Your spreader bar will keep them from drooping again.
Another easier fix is to flip over your aluminum cross shafts. They are offset. You will gain a tone of adjustment this way.
Old May 28, 2013 | 02:12 PM
  #51
Bee Jay's Avatar
Bee Jay
Originally Posted by donyue
Nice job Bee Jay,
The ball joints that came with the A Arms are 20 years newer than the HD Ball Joints on the old A Arms, so I'll go with them for now. What problems were they having with them?
Bee Jay
Old May 28, 2013 | 02:14 PM
  #52
Bee Jay's Avatar
Bee Jay
BeeJay,
I cranked the spreader bar out a couple of turns past no tension. I wonder if I cranked on the spreader bar a turn or so every few months, if that would help?
Bee Jay
Old May 28, 2013 | 02:32 PM
  #53
pauldana's Avatar
pauldana
Bee Jay, have you ever lifted your vett from just the center under the engine? via the crossover? your, or at least mine, shocke toreres will spread apart.. at this time you could adjust your spreader bar very easly, and this may give you what you are looking for..
btw, Chris, my middle son , you meet him a few times, put in some new LED headlights in his jeep... they are all plastic and give amazing ligh... and weigh at about a pound less each light... know its not a lot, but there is 4 pounds right there!!!!
good luck brother! p:-)
Old May 28, 2013 | 02:40 PM
  #54
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Originally Posted by RickyBerg
I now have these SBC arms.
I have so far only tested those on the street but the coming weekend they will taste a bit of track.
I am actually going to get the alignment done today.
//Ricky.
I've posted on a prior topic with these but, many of the 64-72 A-body (Chevelle) guys are tracking these with sticky tires. If they're fine on a 4,000lbs Chevelle, then a Corvette should be no problem. The Chevelle guys get them from SCandC.
http://forums.corvetteforum.com/c3-t...-question.html
Old May 28, 2013 | 02:58 PM
  #55
RickyBerg's Avatar
RickyBerg
Hi there.
I have now tested my control arms on the track and so far so good I must say.
My thread: http://forums.corvetteforum.com/c3-g...post1584007993
Old May 28, 2013 | 04:44 PM
  #56
donyue's Avatar
donyue
Bee Jay
Hi Bee Jay, the problem with the older VBP ball joints has been indicated in this forum from a few years ago. It was advised by forum members that the ball joints being supplied were not very good quality and were wearing out prematurely.
The fix was to replace them with Moog ball joints. I'm not 100% sure that the problem still existed when I purchased my VBP A-arms and thus am prepared to change them to the Moog units if the VBP units wear out.
I believe there is a mention of the ball joint problem earlier in this post as well. My feelings are similar to yours, I will deal with the ball joint problem if it arises. I do most of the actual work on my car, so therefore changing a set of upper and lower ball joints is not a big job for me in the grand scheme of things.
Old May 28, 2013 | 05:20 PM
  #57
Bee Jay's Avatar
Bee Jay
Why would this be stronger than a welded up tubular a arm with a cross member?
To Bee Jay's VBP A Arm install
Old May 29, 2013 | 12:35 AM
  #58
gkull's Avatar
gkull
Jay
I don't understand what Paul said about running 1.5 neg. camber When ever I drove with more than. Anything more than .52 with zero toe or . now .03 toe in I always had excessive inside ware. I drove down to your house and turned my front tires into treadless slicks. But those were those Kumho dot tires that they used for racing They were treadles evenly across the face when I got home and I was having severe push through the turns over the mountains on I-80 on the way home.
Lot's of camber means slop in the bushings..... , wheel vertical travel. and lack of spring/sway. I also have had the bump steer kit that keeps from having camber change
I setup my 295 front slicks with a temp gun and they only needed .46 neg camber
Old May 29, 2013 | 02:38 AM
  #59
RickyBerg's Avatar
RickyBerg
As discussed earlier in the thread, the problem with the VBP upper arms is lack of support for the legs of the control arm to the cross that allows them to flex and bend.
I would say that ANY control arm with a better and more solid construction is stronger then the VBP:s.
Old May 29, 2013 | 10:16 AM
  #60
pauldana's Avatar
pauldana
George, I got this directly from VBP site: and my tires are 300 I believe... just dont have that great of ware??
