Why is Spal so much better than Flex-a-lite??
Old Aug 29, 2002 | 12:36 PM
ericshaw's Avatar
ericshaw
Default Why is Spal so much better than Flex-a-lite??
I am going with dual electric fans... talk around town is that Spal is better than Flex-a-lite.
So what physically or mechanicly makes the Spal setup so much better than the Flex-a-lite setup?
(Please don't tell me you get what you pay for... :rolleyes: )
Thanks!
Old Aug 29, 2002 | 12:49 PM
Fevre's Avatar
Fevre
Default Re: Why is Spal so much better than Flex-a-lite?? (ericshaw)
I have the flex a lit and I am happy with them so far. Guess it depends on your needs. I had them on my engine when it had iron heads and iron ex man and it kept it cooler (below 210 99% of teh time and around 185-195 the rest of the time) than my hacked up set up but still not down where I would have liked @ 180. When I switched to alum heads and headers my temp dropped, now it stays at 180 to 185. If you need the extra cooling the SPALS might be better but if not I wuld think the flex a lite will do. Have only had them on about 1 month so have no long term info to add.
BTW Another thing i like about the flex a lite set is it mounts throw the rad fins with heavy duty zip ties so no extra $ for brackets. Actually I think it came with brackets too if you want to use them.
[Modified by Fevre, 10:52 AM 8/29/2002]
Old Aug 29, 2002 | 01:00 PM
Monty's Avatar
Monty
The Spals are better becuase they actually flow their rated CFM. The motors are more powerful and the overall construction quality is better, OEM quality actually.
I tried the 2950 cfm Flexalite a few years ago and had serious overheating, switched to the Spals and never had another problem - in both scenarios I was using the same BeCool radiator and Stewart Stage 3 water pump.
I called BeCool to see if they had any suggestions and they told me tha tthe Flexalite and Permacool fans were rated in free air, and when placed behind an upstruction such as a radiator, their flow descreased dramatically due to the weak motors that they use. the Spals ont he other hand have more powerful, "high-torque" motors and actually pull more CFM than the Flexalite/Permacools, even though the advertised CFM is lower.
Old Aug 29, 2002 | 01:03 PM
Fevre's Avatar
Fevre
Default Re: Why is Spal so much better than Flex-a-lite?? (Monty)
Good point Monty. Adding resistance will truely test any set up.
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Has anybody tried the Perma-Cool 16" single fans? They are rated 2950 cfm!! I was thinking in swapping my Flex-a-Lite pusher fans (there's not enough space to install them as puller on my 68) for a Perma-Cool Single Puller fan... However - I would like to get some feedback of anybody using this fan...
:cheers:
Olivier
Old Aug 29, 2002 | 01:15 PM
Fevre's Avatar
Fevre
Default Re: Why is Spal so much better than Flex-a-lite?? (GrandSportC3)
Pullers work way better than pushers. I have a open elec fan (no shrouding) that didn't do squat until I switched it to the the puller side. Even the it wasn't great and I suspect it is because it is unshrouded. I think the unshrouded kind work better as a supplemental pusher fan since when they are off, not have the shrouding allows air to flow freely around them where shrouding would get in the way. Is that one the shrouded one?
Old Aug 29, 2002 | 01:32 PM
71'AirStrike's Avatar
71'AirStrike
I owned a flex-a-lot fan in my 58 chev apache
shamless flaunting of my prior toy :D
twice! the plastic fans blades broke after 20-someodd hours of runtime. It did minor damage to the rad fins and destroyed the electric motor.
My theory is that the plastic kit sat on a hot store shelf for a very long time and the fan blades became brittle.
poor quality IMO
cheers
chad
Old Aug 29, 2002 | 03:43 PM
zwede's Avatar
zwede
Spal rates theirs through a radiator core and at 12V. Permecool and flex-a-lite rate at 13.8V and free air. Spals move significantly more air than any other brand. Reason is they use much stronger motors. Flex-a-lite Dual 12" fans draw 19A. Spal dual 11" draw 25A.
Most smallblocks are fine with flex-a-lites. Big-blocks can use spals especially with AC. I tried both on my '71 BB. Flex-a-lite would slowly climb in traffic. I had to shut the AC off when it reached 235F and it would cool off.
With the spals it goes to 210F where the fans kick on, and drops right back to 180F where they turn off.
Old Aug 29, 2002 | 03:49 PM
Fevre's Avatar
Fevre
Default Re: Why is Spal so much better than Flex-a-lite?? (zwede)
For twice the price I would hope their is a diff. :)
Guess I know what ot buy if I start having heating problems. Good to hear they are worth the extra $. I am good for now, thanks goodness.
Old Aug 29, 2002 | 03:53 PM
shawn_cake's Avatar
shawn_cake
Guess I better try the SPAL fans.. :eek: :eek: :eek:
Old Aug 29, 2002 | 05:50 PM
FINWOLF's Avatar
FINWOLF
Default Re: Why is Spal so much better than Flex-a-lite?? (shawn_cake)
I guess I know now where I went wrong hate to have to go buy spal fans now.
Old Aug 29, 2002 | 06:23 PM
ericshaw's Avatar
ericshaw
Default Re: Why is Spal so much better than Flex-a-lite?? (Stephen DeFazio)
What do you mean "went wrong"???
Old Aug 29, 2002 | 06:38 PM
467-Ratman's Avatar
467-Ratman
Another vote for the spal setup, I have twin Spals with my BeCool radiator, works great even with my Big Block! My motor even on the hottest days, 90+ won't go over 205 degrees, and normal around town driving, stop and go the fans keep the temp at about 190-195. They work great are not too loud considering how strong the motors are. I know the BeCool guys well and they have tried many different combos, and they say go with Spal no question!
Old Aug 29, 2002 | 07:56 PM
FINWOLF's Avatar
FINWOLF
I got flex-o-lite in my car and I cant keep the temp under 210 I have a Stewart Stage 2 water pump and the rad is in real good shape just had it to the radiator shop they said it was ok. So I guess I spent the money on the worng fans stupid me.
To Why is Spal so much better than Flex-a-lite??
