Garage Lifts
Old Dec 28, 2015 | 10:53 PM
AW IR C3's Avatar
AW IR C3
Default Garage Lifts
I see a good many posts about lifts on this forum. A few I know well and a few I have never seen before (ie. kwiklift). I sell automotive tool and equipment for a living and lifts are one of my staples. I'd like to give back to the forum and highlight the differences in lift types and some qualifying questions for selecting the right lift for you. I'll focus mostly on the hobbyist grade or lower cost professional grade equipment as I think that's what we're mostly into. I'll also give a general rating system for the types of lifts based on a 1-10 rating with 1 being least and 10 being most for cost, capability, safety, and space usage.
When considering a lift, remember there's generally going to be something for every budget that will get you the features you're looking to have. That being said the last thing to consider in your selection is your budget.
The first thing to evaluate is the expected usage and type of work you want to do on your lift.
- Expected max vehicle weight and size
- Is the type of work you do going to require the suspension loaded or unloaded
- How frequently the lift will be used
- Will you be pulling transmissions and rears
- Do you have any interest in doing your own alignments
- Will you be working on vehicles other than your own
Next lets look at some qualitative aspects:
- Physical restrictions (height, width, length)
- Mobile or static
- Mechanical, electrical, pneumatic
- Power service (110 or 220v)
- Concrete: how thick, level, quality
- Any grade going into shop
Last thing to consider is how important is safety to you. How much risk do you want to absorb vs cost.
Those are the main points to have answers for before moving into the lift selection process.
________________________________________ ____________________
Types of lifts:
Pop Up:
These include things like the Kwiklift:
Cost: 1
Capability: 3
Safety: 1
Space: 2
These are the very entree level of all lift types.
They consist of drive on pop up ramps. You can get cross bridges to incorporate make shift rolling jacks to lift the vehicle off the ramps.
Aside from value the best feature of these is mobility. You can move these and store them out of the way extremely easily.
They are the least safe of all options. Dangers come in multiple forms: 1. Total or partial lift collapse; front/rear, side/side. This lift type relies 100% on friction to maintain integrity. If a vehicle bumps into the lift while it is in the air collapse is likely. 2. Using a makeshift rolling jack setup is inconsistent and can be very unstable. 3. These lifts are not ANSI certified (which can mean they're not able to be used in some states and have not undergone a recognised 3rd party quality and safety inspection. **It is worth it to note that even scissor, 2, or 4 posts lifts are not all ANSI certified, but many are.**) 4. Material quality is not disclosed in detail.
Scissor Lifts:
Cost: 2-5
Capability: 3-5
Safety : 1-5
Space: 2
These lifts take up a small physical footprint and lift from the frame or the wheels. Some have an open center and some have connecting bars. They can be powered by electric or shop air. Scissor lifts come in 3 main configurations, low lift, mid lift, and extra tall lift. They can also have an integral jack (for drive on models) that will lift the vehicle off the ramps from the frame.
They can come in permanent, semi permanent, and mobile configurations.
They can be a relatively safe option so long as you don't try to use it for something it was not designed for, or put something heavy too high in the air or put any axial loads on it. Weight distribution on center-line is also important to consider.
2 Post Lift:
Cost: 4-10
Capability: 4-7
Safety: 1-8
Space: 6-8
These lifts are the most commonly seen lift due to a large variety of uses, configurations, and ease of use.
Like it sounds there are 2 posts that hold the hydraulic pistons that do the lifting. These posts are connected together one of 2 ways, over the top or on the floor. They have 4 swing arms that contact the frame with lift pads. Swing arms come in one of 3 configurations: Symmetrical, Asymetrical, and Versymmetric.
These are generally a very safe type of lift. Each tower has a lock on it giving you a 50% chance of collapse in the event of piston and lock failure. There are 2 dangerous aspects of working with 2 post lifts; 1. Getting the weight in the right place in relation to the lift towers is rather important. Too far forward, back, or side to side can cause the vehicle to fall off the lift while working. 2. If you are pulling an engine, trans, or rear you have to also account for the weight distribution for after the weight is removed. So as you work the danger can increase.
-note* roof height is a critical measurement with overhead cross beams
4 Post Lifts:
Cost: 4-10
Capability: 8-10
Safety: 4-10
Space - 8-10
4 Post lifts are the most capable of all lift types and second most common. They have drive up ramps, like pop up lifts, and use 4 towers on each corner with lift pistons. 4 post lifts in most cases have the ability to add powered rolling jacks that slide up and down the center that lift the vehicle off the ramp base by the frame. They can be ordered with rollers and turntables on the ramps for alignment purposes or for whatever else you can put them to use for.
These are also the safest of all lift types. Most manufacturers have a lock on each one of the 4 towers in case of piston failure. This gives you a 25% chance of collapse due to piston and lock failure on a tower. The largest danger comes from driving on and off the ramps. If you aren't lined up well you can damage your car by driving off the end of the ramps (hard to do) or driving off the side of the ramps (just takes a little care). As you work the vehicle is as safe in the air as it was sitting on the ground.
This is lift info 101.
Please let me know if you'd like me to expand on anything further.
Old Dec 29, 2015 | 12:46 AM
vetteguy22's Avatar
vetteguy22
Thanks for the write up.
I'm in the market for a new 2 post lift for my new shop.
What brand do you find to be one of the better made?
Rob
Old Dec 29, 2015 | 01:02 AM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Great info.
Why not become a supporting vendor here and sell them to CF members?
Maybe a group buy or a standing discount.
Think about it.
Txs
Old Dec 29, 2015 | 06:30 AM
c3_dk's Avatar
c3_dk
Old Dec 29, 2015 | 09:08 AM
AW IR C3's Avatar
AW IR C3
Rob
The company I work for allows me to sell any brand of tool and equipment that will work with me, so I have no dog in any fight between mfgr's. I cover the gambit from lawnmower lifts to 80,000lb truck lifts. All I care to do is match my customers up with what is the best fit for them.
That being said I find Challenger lifts to be of the highest quality in the realm of what we're talking about with Bendpak being my #2 go to.
Originally Posted by bmans vette
Great info.
Think about it.
Txs
I'll consider it. I'm looking to change companies here in a few weeks, so if that doesn't pan out I'll may do just that. No sense to become a vendor and then not be able to sell you anything. On second thought though I may not do it, because if I don't divulge who I work for I have less of a chance of getting backlash for being critical of a particular brand/model.
C3_DK, there's a lot of specialty lifts available in all types of configurations. If you're looking for portability a 2 post would be my last choice for safety. There is no supporting brace between the two towers therefore the entire weight of the vehicle is being held by those under sized bolts (should set in at least 4 inches). So if you're taking them in and out of concrete (even if you have a sleeve in the floor) that will cause fatigue in either the floor concrete, the sleeve, or the bolts. Those are the only thing between you and death. The other thing that truly scares me with that in terms of a hobbyist is that most of us would be down to install it ourselves. A critical piece of lift installation is concrete evaluation, especially with a 2 post. You have to check for depth (4in for 2 post ) and for PSI strength (which you have to use a specialty tool, anyone can get though). Garage pads and driveways are supposed to be 4" thick, however unless you evaluate this you don't know if the contractor skimped on thickness or grade of material or did a rough finish on the ground before pouring. I forsee many people just getting it home and drilling holes for the sleeves without a thought. Lastly, theres no mechanical connection between the two sides to balance the hydraulic pump. If one side gets held up the other side wont know it and you can tip a car that way. For those reasons I wouldn't give that model a second glance. In my opinion. Now Danmar is another very solid lift mfgr on the level with Bendpak and offers other portable lifts. If usable space is concerned I'd look at a 4 post portable.
Old Dec 29, 2015 | 10:55 AM
jim-81's Avatar
jim-81
Originally Posted by AW IR C3
.... You have to check for depth (4in for 2 post ) and for PSI strength (which you have to use a specialty tool, anyone can get though). Garage pads and driveways are supposed to be 4" thick, however unless you evaluate this you don't know if the contractor skimped on thickness or grade of material or did a rough finish on the ground before pouring. I forsee many people just getting it home and drilling holes for the sleeves without a thought. Lastly, theres no mechanical connection between the two sides to balance the hydraulic pump.... .
well said, I could see a lot of people skipping this.
Old Dec 29, 2015 | 12:42 PM
widowmaker221's Avatar
widowmaker221
- Mobile or static
Types of lifts:
Pop Up:
Cost: 1
Capability: 3
Safety: 1
Space: 2
Scissor Lifts:
Cost: 2-5
Capability: 3-5
Safety : 1-5
Space: 2
2 Post Lift:
Cost: 4-10
Capability: 4-7
Safety: 1-8
Space: 6-8
4 Post Lifts:
Cost: 4-10
Capability: 8-10
Safety: 4-10
Space - 8-10
So what are your thought about the Quickjack lift by Ranger? I have been considering one of these for purchase after the new year.
Old Dec 29, 2015 | 12:48 PM
fishslayer143's Avatar
fishslayer143
I bought a 12,000 lb Two-Post lift from Eagle Lifts.. I poured a 24ft x24ft ,6 in deep slab with 36 x36 inch pads ,24 inches deep for the uprights , put 22 inch long anchor bolts in the pads before pouring concrete.. I can assure you mine will never collapse ...
Old Dec 29, 2015 | 01:06 PM
AW IR C3's Avatar
AW IR C3
JESUS! Yea I think you could lift a Saturn V rocket without worries! Got that sucker steel reinforced too?
Good product for what it is. I would keep it limited to its intended use for tire changes and light maintenance or if youre a tall bloke to get the engine up to your height. I wouldnt go pulling trans and rears under there. No redundant safety on that unit. You could also use it to jack the car up quick and get some jack stands on the frame too.
Old Dec 29, 2015 | 02:13 PM
fishslayer143
[QUOTE=AW IR C3;1591209612]JESUS! Yea I think you could lift a Saturn V rocket without worries! Got that sucker steel reinforced too?
double Wire Mesh and 5/8 rebar .. just in case...lol
Old Dec 29, 2015 | 02:42 PM
AW IR C3's Avatar
AW IR C3
Got it...so your garage floor is the roof of a nuclear bunker.
Old Dec 29, 2015 | 03:45 PM
ddawson's Avatar
ddawson
I love mine but I do wish it had two arms instead of one to hold the weight once you relive the pressure.
I did a T5 on jack stands and it was tight. The Quickjack would have been nice for the extra height.
Old Dec 29, 2015 | 03:48 PM
fishslayer143
lol.... no, its just where I keep my PETTY CASH!
Old Dec 29, 2015 | 05:34 PM
SB64's Avatar
SB64
- Mobile or static
Types of lifts:
Pop Up:
Cost: 1
Capability: 3
Safety: 1
Space: 2
Scissor Lifts:
Cost: 2-5
Capability: 3-5
Safety : 1-5
Space: 2
2 Post Lift:
Cost: 4-10
Capability: 4-7
Safety: 1-8
Space: 6-8
4 Post Lifts:
Cost: 4-10
Capability: 8-10
Safety: 4-10
Space - 8-10
I would be interested in the 4 post 101type lifts. Garage will have 10.5 ceiling height. Not sure if that works.
ZIO
Old Dec 29, 2015 | 06:34 PM
AW IR C3's Avatar
AW IR C3
ZIO
PM sent
Old Dec 29, 2015 | 10:56 PM
AkrHack's Avatar
AkrHack
Thank you for creating this thread AW IR C3. I have been presented with the opportunity to buy a used 7000 pound capacity Back Yard Buddy lift. This particular lift will allow me to satisfy my primary objective of providing a place to park another hobby car in my garage at my house. My question is this: is the dis-assembly, transport and reassembly (at my house) something I should consider doing myself? If so, is the weight of the individual pieces (after dis-assembly) manageable for a couple of 50 something guys with a pickup truck to load/unload without much difficulty? If the answer to either of these questions is no, are there companies that will do what I've described for a fee? Disclaimer: I've never assembled and setup a lift before and a value to opinion of someone such as yourself that has years of experience with garage lifts.
Thanks,
Rick
Old Dec 29, 2015 | 11:49 PM
AW IR C3's Avatar
AW IR C3
Thanks,
Rick
If you can physically handle the work and fit it in your truck I don't see any reason not to disassemble and transport it. A lift installer is always recommended when putting up a new or used lift. They have the experience to make sure your years of owning a lift are safe and trouble free. As an anecdote I'll leave you with this: I have a customer who purchased a lift and refused to pay an additional $500 to the lift installer and did it on his own. The first issue he encountered after installation was the floor started to buckle. Found out his concrete was less than 3 inches deep. He un-installed his lift and poured 6 inch pads. Let that cure and put the lift back up himself. This time the lift was not level, off by just a hair. Now it goes up and down with a shimmy, not the best scenario.
As far as who can do it, do a google search for "lift installers near me". Baring success there you can call up the tech line for any of the major lift manufacturers and ask if they can recommend an installer in your area.
If you find you cant transport the lift you can ask any local tow company if they would be willing to transport it on the back of a flatbed. If you have to go that route and the cost of transportation sounds prohibitive and makes you consider a new lift, remember this: when you get a new lift delivered there is typically a lift gate fee unless you have a forklift or someway to unload it. Lift gate fees range from $150-500 for the lifts we're talking about.
Good luck with your purchase and I hope you have many years of enjoyment!
To Garage Lifts
Old Dec 29, 2015 | 11:57 PM
AW IR C3's Avatar
AW IR C3
Thanks,
Rick
Old Dec 30, 2015 | 07:43 AM
donnie1956's Avatar
donnie1956
I used a cherry picker/engine hoist for the ramps as they are very heavy. Thats' is a 4 post gemini.
Old Dec 30, 2015 | 09:07 AM
Gordonm's Avatar
Gordonm
I went and picked up my first two post lift with a rented uhaul trailer. They loaded it on with a forklift and I pulled it apart when I got home. It was about an hour away. My 4 post that I have now I had access to a car trailer. I went down and picked it up the same way. When I got home disassembled it on the trailer. I was able to load the real heavy pieces onto furniture Dolly's and wheel them up the driveway in the garage. Once all the pieces were in the garage I was able to assemble it. If you have access to a trailer that is capable of hauling 2000 lbs you should be able to pick it up.
